🔧 BUILD Turbo 3800 T56 Swapped G-body Grand Prix w/ Holley EFI
So after joining a long time ago, I thought I'd reenter with a build thread!
The car is my 1982 Pontiac Grand Prix Brougham.
Index for people who hate long threads like me:
First time running:
Finally fixed the 4000rpm breakup
T5 Carnage/4l60e swap
Power tour 2018 Mad rush to get done:
Rear Disc brakes swap/axle shenanigans
Power Tour 2019 Prep:
Glamor shots before power tour 19:
2020 quick trip
L67 short block swap and PNP:
2021 Power Tour Prep and T56 Swap:
New Wheels Before Power Tour 2021!
Late 2021 Season Refresh: Bigger Turbo, Ford 9", 1.9 rockers and little fixes:
2022 Updates: Cam swap, next engine, twin disc Monster clutch, Holley Terminator X conversion:
It originally had a Buick 4.1 liter V6 from the factory with a 350 transmission behind it. Back in high school we thought it'd be a good idea to swap an L27 into it since we had it lying around and thought it'd be cheap quick. Anything was better than the knocking 4.1 with only 130hp though. We ended up using a 700r4 as the transmission, but the transmission never played nicely despite our best efforts to fix it. The engine was shoehorned under the hood too so I gave up on it and it has been just sitting around until now. It was a silly idea and I'm glad to be getting rid of it.
Now I finally have plans for the car. I acquired a donor car for the whole drivetrain and am getting ready to go to town.
The donor car is 1998 Camaro with an L36 3800 and a world class Tremec T5 transmission. The car has only 112,000 miles on it and it was totaled in a front end collision. The plan is to pull everything out of the Camaro and retrofit basically everything I can into the Grand Prix. Electronically and as far as the engine and transmission go, it will be a 1998 Camaro. It's getting the engine and transmission (obviously), the PCM, BCM, and basically everything else I can stuff into the Grand Prix while still maintaining its appearance (RKE, RAP, newer chime module, etc.). Everything should have no problem playing nicely and I should be able to reuse my motor mounts, transmission mounts, and also my current driveshaft AFAIK. The Camaro is likely to be parted out afterwards.
Most current pics I've taken:
The main highlight of the build however is the turbo!
This is a Holset HX35. I'm not going for a huge crazy build, but I'm shooting for somewhere around 400 hp with it. The holset should do pretty well with these goals, but I'm considering switching to a HY35 exhaust housing over the twin scroll housing.
We're looking at fabbing up our own manifolds for this and going with a 3" exhaust after the turbo. Also going to be using a 3" intercooler.
The exterior of the car will stay basically stock including the vinyl top. Sleepers ftw :fy:
Other plans include stiffer sway bars, better shocks, and lowering springs front and rear for about a 1.5" - 2" drop. I'm also going to take the body off the frame so we can add more frame bracing since these frames are pretty flimsy from the factory. Also using 16 x 8 IROC Camaro rims for now with probably 245/50-16 tires for now. I might go wider in the rear though.
I've also got an 8.5" axle from an A-body Olds for it. It looks like it'll need quite a bit of work, but I also have a few different sets of ring/pinion gears for it. I'll probably stick with the 3.73 set. The axle supposedly doesn't use c-clips to hold the axles in, but I think that whatever is supposed to hold them in is missing. It'll also need at least a new passenger side axle since the previous owner drilled larger studs in. It currently has disc brake rotors on it, and also caliper mounting brackets that supposedly fit "metric gm" calipers, but I really have no idea what will fit it. In the meantime though I'll use my 7.5" for now with the disc brakes from the Camaro until the 7.5" breaks.
Any idea what these brakes are from?
I know most people with these cars are obsessed with carbureted V8's, but I feel like I've made the right choice here. The V6 will be much lighter than a V8 especially with a manual transmission. This will help to remove extra weight from the front of the car and bring it closer to a 50/50 weight ratio. It'll also offer a ton of power and still give great fuel economy. Not to mention I can also tune it with my laptop! I suppose the idea is it's basically a Pontiac Grand National but with the more modern 3.8, more power, and a manual transmission.
The biggest challenge will be getting the turbo in here, and also getting the manual transmission into the car. Luckily the T5 uses a hydraulic clutch so clutch fork geometry won't be an issue. I'm still a little bit hesitant about cutting up my floorboards for the shifter though. It's looking like I will also have to do something about the seats since the shifter will sit where the middle seat is at. We'll see about using a center console... Those bridges will be crossed when we come to them though.
The first challenge was transporting the car over to my brother's house where there's a garage I can work on this in. I originally tried to just drive it out there, but the engine pretty much said "fuck this, I'm done". After a long night, we ended up trailer-ing it the next day.
Here it is finally in the garage last night:
yeah, it's dark. my bad.
Progress!
front clip removed:
engine removed:
I'm powered by Rockstar!
So much room for activities!!!
So basically all of the remains of the L27 are gone. I have also started to separate the body from the frame. I got all of the body mounts disconnected, but called it quits after attempting to remove the rear bumper. Hopefully I can get the body off the frame tomorrow and get started on removing the engine and transmission from the Camaro. I've got a long road ahead of me, but I'll have this done for the Woodward Dream Cruise I'm sure.
Thanks for reading!
bs009
Making 3800's Great Again
Feb 13, 2014
698
2,129
NashVegas
Managed to finally get the downpipe finished today. Took way longer than I thought it would but I managed to squeeze that thing in the tiny area I had for the downpipe.
I'm dubbing this mess of a downpipe THE POWER VORTEX!!
Was a real PITA to figure out where to put the bends at to snake its way down there and where to put the v-bands so I can actually remove both ends of the pipe. This actually came out way better than I thought it would though so far!
Tomorrow I'm hoping to at least get the wastegates tacked into their new positions.
bs009
Feb 13, 2014
698
2,129
NashVegas
Got the wastegates set where they're going to go. This should hopefully allow the wastegates to work a lot better now that exhaust gas is a bit more directed into them.
Also should be way easier to change springs now that they're up high and easy to get to
Here you can see where the manifold splits between the turbo (down) and the wastegate. Should see a lot more gasses flowing into the wastegate than before with this
Lots left to do still. Manifolds are coming off next to finish the welds and clean up any metal shavings inside them.
Also going to change the timing chain while the turbo's out of the way and might as well change the rear seal while all of the fluids are drained.
So my list to get this thing on the road again looks like this right now:
- timing chain
- rear main seal
- finish welding exhaust
- retorque heads just in case
- install new clutch and trans
- build a new 3.5" -> dual 3" exhaust
- swap rear axle
- and all of the little things in between
bs009
Feb 13, 2014
698
2,129
NashVegas
Well I think I found the source of one of the harmonic noises/vibration I was feeling on the car. They flywheel shield was rubbing on the flywheel apparently. I knew it was tight but didn't realize it was that tight. I'll just trim it down now so it's not as tight up against the wheel. I also replaced the rear main seal again while I was at it. I went and bought the dealer tool to set it in there and an ACDelco gasket so hopefully it doesn't leak again.
Verified my cam timing wasn't done wrong from before too. looks like I did retard it the way I thought I did.
I've put it back to the L67 timing though now so that should allow me to get back the top end power that I was missing on the dyno.
Also adding rockers too to this thing. these are ZZPs 1.9 ratio
Moving the wastegates allows me to run a much bigger air filter than what I ran before and won't need to have a crazy tight bend in there to make it fit.
I'm also pretty sure the old warped filter was a huge restriction here too.
Secondary 3 bar MAP sensor so I can actually log boost over 15 psi in uvscan
That one is for a Duramax and supposedly is not that good as a primary MAP sensor since it can't read below 30 kpa. I may end up running it though in place of the two bar down the road if I can get the PCM to read it properly. For now its data is going straight into my DHP box.
Fancy new steering box that still actually leaves some play in the steering wheel :rolleyes:
That's a wrap on the exhaust! Or at least the exhaust under the hood
bs009
Feb 13, 2014
698
2,129
NashVegas
Nice! I thought about running an extra map sensor somewhere and running it to the prolink but I never got that far and I'm not quite sure how I'd get it to transform correctly to read it in vcmscanner but I'm sure one way or another it could be done
I'm thinking it's just going to be linear reading from 0-5v for 30kpa - 330kpa, but being able to log both at once is going to show me for sure and also how far out it is. I've heard there's more room for error in the 3.3 bar MAP sensor.
I'm new to HPT but I'd assume you can just give it a formula to translate the voltage into a pressure. This sensor was pretty cheap compared to a lot of the others I was seeing though at least!
Reactions: sktchy
bs009
Feb 13, 2014
698
2,129
NashVegas
Mostly done under the hood for now. Waiting for my new clutch to arrive still so I started working on the rear end finally.
This is a quick performance 9" rear end. I had them put on axle flanges for a 98-02 f-body so I can reuse my current disc brake setup and save me some money. Also using the GM bolt pattern here too.
Took probably 11 weeks for me to get this thing from the day I ordered it, but it looks pretty good at least.
lot of money in this picture ?
It's looking like I might need to add bump stop brackets to this one, then also the shock relocation that's typical for this disc brake setup. I also have vent filter coming too for it.
Discovered last night that I'm going to need to press on the bearings to the axle shaft because of my disc brake setup here. Looks like the 98-02 f-body brake bracket is going to act as a retainer for the pressed on bearing to hold the axle shaft in.
It makes sense but I wasn't ready to have to do that. Might have to go buy a harbor freight press or something.
bs009
Feb 13, 2014
698
2,129
NashVegas
Welp I bought a press. Made this job super easy for sure.
To attach my hellwig pro touring sway bar I needed to mount the brackets to the axle without using the U bolts it comes with because the back brace on the axle would get in the way. Out comes the welder again to make them fit and it's way better than using those u bolts
Also needed to relocate the shock mounts on the new axle too for the f-body disc brakes. This seems like a better way to do it than I did before
3.5:1 Eaton Trutrac
Starting to come together now
Now I just have to figure out if I wanna run bump stops on this too. I could cut them off the old axle but thought I'd try and sell it complete though and see if I can get some money off of it.
bs009
Feb 13, 2014
698
2,129
NashVegas
Finally wrapped up the rear end on this thing. Made a few bump stops using a set of the f-body rubber pieces and then made a tab for the brake splitter.
Car is finally resting on the axle in the back again!
Just need to finish the exhaust before I can get the tires off the floor and bolt them back on.
Another big piece of the puzzle arrived today
This is Monster's most basic twin disc clutch and is rated for 700 hp/tq
Looks really good and I'm stoked to get this thing in the car!
but...
Looks like they zero balanced it instead of matching the weight of the oem flywheel I sent. It's possible the weight is in the pressure plate/second clutch assembly, it is marked to only go on one way.
I'm going to check with them but I think I might have to figure out how to get this thing balanced.
Back when I was trying to do this in August there was nobody local I could find that was willing to do that so I'm expecting this to be a debacle to figure out.
Zero balance would be amazing if I were building a motor and could have it internally balanced, but it's looking like I have yet another hurdle to solve for this thing.
Might be ordering another spec to get the car back on the road again this year if I can't find anyone to balance this thing.
bs009
Feb 13, 2014
698
2,129
NashVegas
Finally found a local place that was willing to properly balance the new flywheel that came with the Monster clutch last week. Sounds like it's going to be a few weeks before they get it all set though. No surprise there with the way things have been going for the last year.
I'm really itching to get the car back on the road soon though. Hoping I can get it up to Michigan to see some family this week so I'm going to button things up pretty much as they are and hold off on the exhaust upgrade until afterwards.
For now I'm going to be installing this spec stage 5 clutch though so we'll see how that works out. Supposedly there's no friction zone on this at all but it should be able to hang in there a little better than the stage 3+ I had before.
I really only have like 2 days to work on this if I'm going to drive it out Friday night so it's going to be an interesting week. I thought I had more time but forget I'm flying out for a work trip tomorrow so I'm losing a few days of wrench time. I'm not too worried though, I think I can make it happen.
bs009
Feb 13, 2014
698
2,129
NashVegas
Well so far it looks like my mad rush to get the car going again is going to pan out.
Since I was so short on time I didn't bother to do the full exhaust upgrade I was planning on doing, but I was at least able to get the 3.5" downpipe to connect up into the old 3" exhaust. There were so many little things I had to do that took forever, things like boost control lines, driveshaft u joints, and shoehorning a 3.5" downpipe with oxygen sensors in the tiny amount of space available. I was up until 3am last night working on this thing before I finally fired it up.
It's finally back on its own wheels again though
Fired up the car again last night for the first time since August and had nothing too crazy happen. The exhaust is way quieter than it was before now that I've switched over to the MLS exhaust gaskets installed new bolts with these wedge lock washers.
Hopefully those keep the manifolds from coming loose again this time.
I did notice a really loud lifter tick when I started the car up. Eventually it did get quieter but I can definitely still hear it.
For some reason the car is also throwing a P0121 code which makes no sense to me at all. I'll have to try to track that down tonight before I do a test drive before leaving for Michigan tonight. Hopefully the lifter tick will eventually go away, I can't remember if I put in the newer LS7 lifters in this engine or if it still has the lifters I installed into it 70,000 miles ago when it was in the Regal. My guess is they're just whining about the LS6 valve springs though and just need to get some oil running through them.
Car's had a lot of changes since August so hopefully it all holds together.
bs009
Feb 13, 2014
698
2,129
NashVegas
I've had pretty good luck with the stock bolts but I'm having to use stainless socket cap screws because of how tight everything is in here. Even with those it's still a pita to remove the manifolds though :ROFLMAO:
I'm hoping to fix that in the future though
My truck though is a whole different story. I have to tighten the stock bolts every oil change because 1 or 2 like to get up and walk away. I have a few spare lock nuts though I'm going to throw on there and see how they work.
The old guys I've talked to about this though recommend this type of lock washer. Not sure if it's the same exact one though.
Never considered lock tight though, always figured it would be too hot for it
Reactions: v6buicks and sktchy
sktchy
7,744
12,015
It probably is too hot for it but I generally don't think about things like that until after the fact ? I do know the cartuning pipes are a royal pain to get a wrench on in spots and there's a couple that you have to use the box end on and go an 1/8 turn at a time and for those I nipped the excess off the tops of the stock studs so I really didn't wanna have to mess with them til I pull the motor again.
Spark plugs are just about as much fun to get to
bs009
Feb 13, 2014
698
2,129
NashVegas
So I took the car around the block, new turbo lights off crazy fast but that might have more to do with the new rear end though than the turbo. It sounds way different than the old one, sounds like one of those electric turbos that Cleetus tested on his cobalt a while back.
The exhaust note sounds ungodly amazing after all of that exhaust work, a 3800 should not sound like this at all :ROFLMAO:. Sounds a lot like an RB motor now IMO, I'm going to have to put together some videos or something.
It is misfiring really bad anytime I put some load into it though. I'm pretty sure my plug gap is down to like 0.020" but I'm going to let the car cool off for a little bit and swap out the plugs before I try to leave tonight. Maybe that'll solve the issue but who knows
