Tuning Question
FuelSlut
FK RED STAR
Nov 9, 2005
1,969
Afer I install the KB, I want to run 17psi for the street, and instead of just getting a more aggressive tune I want to run 19-20psi for the strip. Now how do I have the tune done? DO I just fill it up w 100 octane and do both tunes on that and just swap pulleys in between, or will the 17psi tune be affected a little because of better gas. Do I do them seperate 17psi on 93 octane, and 19+psi on 100 octane or better? How does Sutton usually do this? If any of you guys run a combo simular to what Im talking about?
DSG03COBRA
1,746
Plainfield, IL
If you want the 17psi for the street, then I would suggest getting it tuned with whatever gas you typically run on the street. (93 most likely) If you were to put 100 Octane in the car with the tune set up for 93 Octane, you wouldn't have anything to worry about. If you had a tune set for 100 Octane and you only run 93, you would most likely start having detonation and possibly damage your engine.
So get 2 tunes... 1 for 17psi on 93 Octane for the street, and then another for 19-20psi on 100 Octane for the strip.
  • FuelSlut
  • 2
  • 279
