How much did you adjust your maf the few times you've done it? What %?
and yes a 3.6=win on a stock car. I'm running a 3.35 with a dp/intake and fail on kr. I just turn the knock sensors off, spark plugs say they're lying
That's what I was thinking.Looking at your tune/scan i see the typical gtp guy running a 3.4 pulley on a completely stock car... WTF eagle? more boost and low timing on a turbo car = win, less boost and more timing on an m90 car = win. Other way around (i.e. eagles junk) = fail.
ok, so that's not working, what's your email addy? I'll send you a fixer upper! Well actually send your current one first [email protected] and i'll screw around with it real quick, then copy differences over and try that. holla.
whats this ported downpipe you speak of?
can't you calc boost somehow by sensor output captured by the scanner?
I think that downpipe is not super high flowing. It's still using a stock flex right?
Headers + stock catback = win
rly
I got it from Bru after my 3" downpipe that came with the car blew out on the way home after buying the car.
I guess FLP ported the flange and put in larger pipe to the cat, then took the hump section out and replaced it with something straight and slightly larger...
You need more camHeaders + stock catback + stock pulley = fail on my car
