trouble code and opinions?
WhtSuperStang
Jack Bauer > Chuck Norris
Ok last night my check engine light came on in the Focus. I had it scanned today and it came up with P0125
A code P0125 may mean that one or more of the following has happened:
* Insufficient warm up time
* Low engine coolant level
* Leaking or stuck open thermostat
* Faulty coolant temperature sensor
Now here is where i need some help..
- The car heats up nice and Hot still and relatively quick
- Its getting ass gas mileage now (doubt its related but it started this week)
- For a couple weeks I have noticed on and off smell of coolant..but when looking under the hood i dont see any leaks or when i look under the car. As well as no drips on my driveway...
- Coolant level seems to be ok
Has anyone had this code before or is this a common problem?
WhtSuperStang
WhtSuperStang
Leaking thermostat housing probably
Thats what Hans seems to think as well
Is that a common problem with these cars? (I know jack shit about the svtf) also where is the thermostat housing located?
Rotard
No respect
Very common problem, the tstat housing is located right around the intake manifold I believe (haven't been down there in awhile). Take off your intake and you should notice it right away.
WhtSuperStang
WhtSuperStang
i was reading the piece of shit is made of plastic? i wont need a new housing just reseal it and a new tstat while im there right?
Rotard
No respect
If the housing is not cracked then you will only need a new seal. I would get a new housing though since they are pretty cheap anyway ($60 bux or so) BTW the clutch master cylinder is also plastic so get ready for that to go at any moment 2 :mad:
WhtSuperStang
WhtSuperStang
do you think that the housing and shit would be covered by an extended warranty?
macdiesel
Thermostat housing is at the rear of the engine in front of the ignition coil. It can leak with little to no puddling. If you smell coolant, most likely leaking. Might see coolant build up on bellhousing if you look below the thermostat housing.
Should be covered under warranty. But I've never heard of getting that code and it being the thermostat housing. Usually when the thermostat housing goes the symptoms are having to add coolant, smells or pooling of coolant under car. Maybe the sensor is bad if your mpg's tanked?
FuelSlut
FK RED STAR
Do a search on coolant leaks cheap fix. I wrote a detailed description of a VERY common (as in ALL) Foci leak. The aluminum plug under the t'stat housing has an o-ring seal. Ford used the wrong grade of rubber. If you car has about 20K miles or more, and it only leaks coolant when the waether and the engine are cold, this is it. The fix is a 50¢ o-ring. Find that thread.....
Chris I heard about this problem a while back and got ready for the day it started leaking, so I went to auto zone and bought a set of viton o ring seals wich are the right grade! It's very easy to fix it's right under the thermostat housing left side of intake.
WhtSuperStang
WhtSuperStang
Thanks Dan!!! you are the man, i will check it out and see what my warranty can do! I appreciate the follow up even after how long its been!
Dan = kickass!
FuelSlut
FK RED STAR
Dan = kickass!
It's no problem at all, I'm just trying to lend a helping hand. I would have responded sooner but I didn't see your post. And if you want I still have that package of o rings I never installed you can have them, you just have to figure out what size it is there is like 8 rings.
If you do take it in foe warr claim make sure you tell them to replace it with a VITON material o ring, they can tolerate like 3 times the heat than the cheap ford one!
