This is gonna sound CraZy, but I plan on doing this build and keep my MM active as a DD. I had a chance to get started fabricating some of the small stuff. Here's how I made my I/C reservoir bracket
These were easy to make, I used a piece of angled 1-1/2" aluminum stock and hit them with 2 coats primer, 3 coats semi gloss paint, then 2 coats of matte finish clear coat. I began by making a cardboard cut out of the fender contour, then transfer it to the aluminum stock
To install the bracket you have to remove the mount for the shock that supports the hood with a 1/2" deep socket.
Ya'll excuse the dust on my engine compartment, it will get a thourough cleaning after I'm done with the install. You will need to put a flat screwdriver through the slot to remove the shock
Give it a pull and it comes right out
Slide the bracket into place then reinstall the shock for the hood
I made the mount so it has 3 points to bolt to the fender, this will keep the reservoir from vibrating while driving heres a pic with the reservoir inplace
The short bracket I made goes under the reservoir to give it strength, soo it's a sandwich design. I didn't feel comfortable bolting directly to the bottom of the plastic unit.
Here is a side shot of the install
I had a little extra time so I fabbed up some PCV lines out of 5/8" aluminum tubing, the ends are flared and my plan is to paint them black to blend into the engine compartment
Now I have plenty of clearance for the top hose to connect to the reservoir
Next in line is to get the heat exchanger installed and plum the pump
