Sup TCG,
The ever revolving debate in my 3800 Camaro is what transmission I'm going to swap in. The only things I know is that the T5 is screaming for mercy, and I want to swap it to a strong automatic before I get it tuned. The car has a 3.42:1 final drive, I drive it mostly on the street (rarely on the interstate though), and I'm not interested in pricey electronic controllers or TV cables.
My latest idea was doing a full manual 4l80e so that I would have overdrive. There's a little diode box you can buy that just runs off a switched 12V and a ground switch for converter lock-up. It sounds like a cheap way to get old school simplicity and beef along with modern overdrive. However, fully manual function sounds like it could be a nuisance. Are there any sprags you can explode in a 4L80e if you forget to up shift or neutral before slowing down? Is full line pressure all the time going to make me hate driving it?
How about a TH400 or 350? Those are simple too. I've heard that there are some fairly simple mods you can do to convert them for boost and fully automatic function, but I've also heard that it might require conversion to a TV cable. That's not happening because I have an electric throttle. Of course neither one have over drive, but maybe I'll be okay when cruising since my commutes have a speed limit of 60mph anyway?
I don't know! What have you guys driven?
