Track Newbie
chipmonk212121
So sunday when I come out....what do I do? never been before and ya..... do i need to bring anything....like a huge wooden spoon or anything?
Fish
From the mean streets....
Chiraq
I would say a ratchet and a 10MM socket, but since you have an 04, the headlights are easy to take out. (to let more and cooler air into the airbox.)
Tire pressure gauge if you change the pressure in the front tires.
Yourself ;)
Your car ;)
That should be it.
chipmonk212121
its completely stock i got it like 3 weeks ago......is it even worth racing?
Fish
Chiraq
If you plan on modding, its good to get base numbers. Every car is different.
Plus its good to try and win some prizes. :D Being a stock GT is good for brackets as long as your consistant and good with reaction times.
Since you have never drag raced before at a track, definatly practice on R/Ts while its test and tune.
chipmonk212121
how about I find you and you can just give me some guidance..... and if i win anything you can take the credit for my glory! that is if you have time and your willing, if not its cool ill survive
Fish
Chiraq
I actually wont be there. :( Im sure others will help you out at the track though. :D
chipmonk212121
ok cool thanks anyway..... ok if anyone sees a 2004 GT with the owner walking around aimlessly thats would be me, ok i wont be that aimless.... but if anyone could help me out i would greatly appreciate it.
TonzKnock-G
Shitcago
[snapback]98667[/snapback]​
I have a BIG FAT k&n filter you can use race day. Slap it right off the end of your maf sensor. Its my winter filter but currently Im using my FWI setup for the hot weather. I was going to bring it anyway and compare it to the FWI setup. Just bring some simple tools to take your stock airbox out.
horist
Geek
Lake Zurich
Regarding what to do at the track... few things to remember:
1. Drive AROUND the water box... don't drive through it on street tires (it drags water up and hurts traction for other cars)
2. No need to do a smokey burnout on street tires... spin them to clean them off... that's it
3. Line your car up in the "groove" .. you'll see 2 lines where other cars have layed down rubber... line up in that groove
4. Courtesy Stage... Drive up just enough to trip the FIRST set of yellow lights... then trip the second set when the person in the other lane trips the lights
5. at US41 the exits are on the left, there are 2 I believe (maybe 3?) ... if you're in the right lane, do not exit until the car in the right lane has exited (even if it's a 30 second minivan, worst case wait till you get to the end by which point your opponent should have exited.
6. watch your speed when exiting... the speed limit is 5mph which is ridiculous... but don't go driving through at 45 , it's dangerous
7. Leave when the 2nd set of amber lights flashes... by the time you react the green will be on.
I
imported_PaceCarBoozer
[snapback]98684[/snapback]​
May be a dumb question, but whats the water box?
horist
Geek
Lake Zurich
Originally posted by PaceCarBoozer+Sep 23 2005, 12:54 PM-->
<!--QuoteBegin-horist
[snapback]98686[/snapback]​
[/b]
when you're pulling up to the the line, before it is an area with water... this water is used for cars running slicks or drag radials... tires that need to be hot to be sticky... the water makes it easier to break the tires loose so you can heat them up.
There's enough room on the side of the water box (left side for left lane, right side for right lane) so that street tire cars can drive around.
For RWD applications, if you're running a slick/drag radial in back but stock tires up front, you drive around and then back into the water box... then drive forward and light them up... RWD w/skinnies up front (real skinnies not radial skinnies) cand rive right through the box.
Technically FWD cars should have skinnies in back in order to warm the front tires up, but this isn't very practical so unless it's a large racing series you generally can drive through the water box to heat the front tires up (if there's anything large going on like a summit points series driving through the water box w/out skinnies will not make you any friends)
since you're on a street tire, just drive around the water box, hammer the gas to sping the tires thus cleaning any gravel and such on them, thenpull up to the line, courtesy stage and you're set.
Another thing you *may* see (it's not real common) is deep staging... you can roll forward so that only the 2nd set of yellow lights are set... this gives you a couple foot advantage, but is rarely done... not sure if it'd even be allowed in a points race.
I
[snapback]98688[/snapback]​
[/b]
very informative, thanks
chipmonk212121
sweet thanks everyone.....im still gonna mess things up but thats no biggie its my first time!
I
imported_Ron Vogel
Also, when you stage...just tickle the second staging light. The clock doesn't officially start until you leave the beam. The little time betwwen once you start moving and when the beam breaks gives a little bit of a start that helps MPH and ET's through the traps.
I
[snapback]98696[/snapback]​
Coochie cooo, tickle, tickle.......so what your saying is when the tree giggles, punch it, haha, sorry the smartass in me made it impossible to leave that one alone.
