Torque specs for tie rod end/castle nut
m_dogg
Brookfield
Getting annoyed with different answers online...I've seen anywhere from 35, 45, 52 ft/lbs for the outer tie rod end nut. Anyone knows what it should be? I torqued it town to 45ft/lbs but then the castle nut is quite a few turns past the cotter pin hole which worries me a little...Original tie rod ends didn't use cotter pins but the nut was much larger.
Harbor Master
whatever the impact is set to
:s00ls:
m_dogg
Brookfield
I mean what's the use for the stupid pin at this point? Do I put some loctite on it at least or wait for it to burn to the ground?
RICH17
Dr. Pussy Slayer, MD
The 007
ummmm that's not suppose to be that way. I wonder if you got the wrong end?
m_dogg
Brookfield
Yeah...both sides are like that. I mean that looks "different"
RICH17
The 007
Unless your knuckles got hogged out for some reason, the boot shouldn't be that close to the knuckle
boostedguy05
not well known
cotter pin for dummy fail safe? thsi way if a DIY'er screws up but has a pin in to hold it to get to a shop.
10sec
Something is not right here.
Joint is a pull together joint, there is a chance the joint could "expand" and the nut can become loose, that's why there's a cotter pin. You need the cotter pin.
m_dogg
Brookfield
It's actually Moog. I'll try to replace it with Delco or Napa, went to my friend's shop he laughed about the idea of washers and recommended OEM rods. We'll see...
boostedguy05
not well known
i have a box of new stuff sitting in my basement. let me check how close the hole is to the end. its in the pile of stuff to drop on james's door step and run.
Jfrost
Fiero's are addicting
Brookfield
I used MOOG tie rod ends on my old GTP and remember they didn't have that issue with the cotter pin holes. Something's wrong as others said.
m_dogg
Brookfield
Right knuckle cracked...
Pulled the left tie rod off, waiting for more parts.
:fu:
