TODAY ONLY ridgid 1/2" impact combo $149
Thirdgen89GTA
Posts
13,718
Buffalo Grove
Keep the boxes.
Boxes have a model#. The 1/2" is R86011SB. The 3/8" is R86239SB.
Make a Rigid account, and there is a link to register.
Then you register the tool, battery, and chargers. And they all fall under the lifetime warranty.
Not sure about the batteries though, they will eventually wear out, I can't see them replacing them forever and ever.
Thirdgen89GTA
Posts
13,718
Buffalo Grove
They have auto-sensing torque too.
On the 3/8" in low speed it stops at 15ft-lbs. Med = 50ft-lbs, and high is 100ft-lbs.
So if it were accurate, then the 3/8th should be just about right for lugs on a car.
"and the world is full of dreamers"
Posts
57,323
Yea 1/2 inch battery guns are now waaaay more than enough to zip on lugs
Thirdgen89GTA
Posts
13,718
Buffalo Grove
Finally had a reason to use the 1/2".
Having the electric impact literally knocked 45 minutes off the time it takes to properly swap the tires on my RS for winter.
it was so nice to just zip the lugs off without having to hand loosen everything while the tires are on the ground, and then ratchet them off.
And the Auto Stop feature is fucking amaze balls. It'll stop as soon as its hits the first Ugga Dugga. I put finger threaded the on, then nascar style ran them down on Auto. It put each lug at roughly 50-70 ft-llbs. All I had to do was roll around to each one with the ratchet and I only got about 15° extra turn, which is right around 100ft-lbs with my 1/2 Ratchet.
And my back hurts nowhere near as much as it usually does when I have to manually do it with the ratchet.
That Auto mode is pimp!
m_dogg
Posts
3,986
18-Volt Brushless SubCompact Drill Driver and Impact Driver Combo Kit with (2) 2.0 Ah Batteries, Charger and Bag - free tool
Needed new set anyways plus 3/8 subcompact impact free. Not bad.
daturbosix
daturbosix
HNIC @ GoodFellas Garage
Posts
14,138
Just had to buzz a wheel off my caddy for a flat and this thing didn't hesitate at all. Previously put them on and torqued with a snap-on 1/2-in drive electric uggaduga machine..
Not bad at all
