The newer trend seems to be a higher spring rate than what used to be recommended in the rear and a slightly softer one in the front. While a completely different animal...I believe my rate in the rear is now 275 and 450 front (IIRC). This pic is when it was too low to not be white knuckled while city driving (Ridetech level 2 550/160 4 link rear):
It's a little bit higher now and still in a rebuild with a completely different suspension again.
I went with fairly large sway bars. I’m not afraid of a rough ride if it’s planted in turns. Really just looking for a fun canyon carver since there are so many good roads here.
where is [MENTION=148]HILROD[/MENTION]
infinite wisdon
Is there a link to the sway bars so I can see what rate they are?
If you drop too much than the tie rods get at an angle that is not parallel with the other parts you will get bumpsteer.
Honestly I would get it put together with what you have drive it and see what it feels like and if need be go to a higher or lower spring rate.
Pretty sure these are the ones my wife bought me. My car never came with a rear and the front disappeared somewhere so she surprised me with some.Is there a link to the sway bars so I can see what rate they are?
I think I've decided to keep my stock style setup and run the hotchkis springs I have and the QA1 single adjustable shocks. Have you ever installed any? Trying to decide on the best course of action to open up the access hole while not compromising where the shocks mount on the stock A arm.I WAS BUSY! Now coil overs are a compromise on most front end swap in. Mostly they are too short to work real well unless you run them super stiff. I personally would never use them on a stock front suspension. If you are dead set on it keep the ride height as high as you can and use their arms to fit them. If you use a front spring like a Hodgkiss or Detroit speed and any decent front shock you will be way better off. Don't be scared of higher spring rates,I think I run 700+ spring rates up front and it rides decent. Just make sure you have good control arm bushings, not rubber.
450lb up frontThey’ve got a bunch of spring rates available. Do you know which ones you have up front?
Umi has a kit for that I think but it’s expensive and yea you have to modify the frame quite a bit.I've seen someones coilover kit that cuts out the upper spring mount/shock hole so you can run a longer spring/shock, but don't remember who sells that.
So, your reason for wanting to cut is you cannot get the shock through the hole to install?The diameter of the shock is what doesn’t fit, not so much the knob.
I’ve always changed shocks thru that hole on any gm. I’ve never once had to pop a ball joint and remove a spring to install a shock.........So, your reason for wanting to cut is you cannot get the shock through the hole to install?
Usually you pop the spindle off, unbolt the shock/cut the bolts and then use a jack to raise everything in place. The shock does not go up through the arm. Bolt up the top and you are done.
