tinted tail lights
  • Thread starter imported_silverbullet
  • Start date
I
anyone recommended tinting the tail lights? i'm thinking about doing it but kinda worry about someone might rear end my car cause they might not see my brake light. good idea or bad idea?
I
imported_1fastGTP
my buddy has them done and h only did 1 coat so u can still see the light when u brake and it looks good on the black so i wouldnt be worried about sum 1 hitting you.
98GTPDriva
Just do one coat at a time and then see how it looks. If it is still too light for your liking, then add another coat. Your worst case scenario is that you mess up and buy another pair of used stock taillights.
When you're all done with tinting them, add some clear to make them stand out a bit more.
xttc2000
ive tinted several sets of taillights almost compeltely black, and the driving lights/brake lights shine through just fine.
i use almost an entire can of nightshade and slap a few coats of clear coat on it.
do very LIGHT coats, then let it tack up, then another coat, and so on.
I
imported_PaceCarBoozer
where do you get the stuff to do it, and is there any prep that needs to be done to the lights before applying it?
CJ
BigJermGTP
Montgomery
CJ
[snapback]106443[/snapback]​
Im not sure where you can buy this stuff, Ive honestly never heard of it, maybe someone can chime in because Im curious as to what this spray on tint is.
Either way please use caution when painting plastic!!
Tail lights are considered bare plastic which means that there is no primer on them. If anyone paints any kind of bare plastic you need an adhesion promoter in order for the paint to stick to the plastic. The only sanding/scuffing you need to do is use a fine scuff pad to ruff up the surface a little and spray the adhesion promoter over the plastic after they've been cleaned. After that is sprayed on you can be absoutly sure that the paint wont ever peel off.
This is why im curious to see what this product is and what the directions say for application.
Please again, i just want eveyone to know that you cant just go up to interior panels or tailights and spray them without proper prepping. READ THE CAN!!
Ive seen too many people's car look like shit a year later when the paint starts peeling off their interior panels.
Fish
From the mean streets....
Chiraq
summit racing sells niteshade. Only way to go if your gonna DIY.
Sinister Drag Designs
SinisterDragDesigns.com
Chicago, IL
[snapback]106371[/snapback]​
pm raven he has them done with one coat of car paint, they are perfect and look awsome, but he changed to the brighter reverse ligths, just to get it back to stock, that was the only real prob, when you hit the brakes they are bright still, but cruising they are darker,not to dark , just dark enough, well legaly i dont htink you could go darker, i think unvmygtp had it done to but he did it differntly
:blink: pm both but talk slow to raven it takes him time to think
PANDA
FRG
I wouldnt worry about someone hitting you, but if there really really black, idk you could maybe get a ticket.
Got any pics what GP tails look like tinted?
Fish
Chiraq
The light would come right through when you hit the brakes or the lights were on.
PANDA
FRG
Damn, that looks really good. Whos shop is that? I see six Grand Prix's.
syP
Not Banned
Downers Grove, Illinois
LP 3800's machine shop..
that was at the ILGPC mod day summer of 2004... when INTENSE was cool.. and i wore my ZZP shirt... oops
Fish
Chiraq
[snapback]106504[/snapback]​
Actually, that was January 2004. It was winter out and we parked inside and washed our cars.
