OK well sorry it has been a few, the holidays and all kept me pretty busy. Hope all my TCG fam had a fantastic Christmas!
Well I was able to get the rear end reassembled. The weather was getting colder so I didn't take a lot of pics of the reassembly but looking at the teardown pics I think you guys get the idea! After the rear end was all back together I did grab a pic of everything put together. I also took some time to clean up the frame underneath and I am very pleased with how everything came out!
Once all together, it was time to bleed the brakes. Of course my OCD kicks in and I think to myself, "Update and replace anything I can that is 40 years old and prone to rotting or failure. So my sttention went straight to the master cylinder and servo assembly. To access this, you have to remove a panel in the frunk or "bonnet" to see it. There is a small access door to add and check brake fluid, but you cannot really see the whole assembly. Sure enough I removed the access panel and saw this (this was after I removed the reservoir of course.....
The servo was soaked in brake fluid. I had took note that a lot of the rubber gaskets were hard and probably failing. I was able to track down a full Girling master cylinder rebuild kit and servo kit and thus began my work!
Old rubber seals:
Here is a wide shot to show you how you get to this stuff! The hard pain was removing the bolts on the servo. Tight spaces!
With the servo booster out, I gave it a good cleaning and replaced all the o-rings and associated hardware:
Once everything was reinstalled and cleaned up I began the brake bleed process. I cannot stress enough about using a power bleeder tank to force all the old brake fluid out. My brake fluid has not been changed in 2 years and THIS was what was in my system. As brake fluid breaks down it becomes very acidic and eats up and corrodes internal brake components. If you have an older car and this has not been done lately, I highly recommend it!
So once this was all done I decided to take a break from working on the car and take it for few test drives. With the rear suspension alone completed, the car already drives like a dream! Not to mention i had to snap a few Christmas pics for her Instagram account! Here you go, enjoy!
I will be back at it shortly after the new year, so dont worry I will post more real soon! Have a Happy New Year everyone!
