Time-Cert Thread Repair Inserts - Local Place to Buy?
TommyGloves
CHICAGO
Does anyone know of a local place to buy Time-Cert thread inserts? I need to find one of these to get my trans case fixed. TIA.
M10 X 1.50 X 22.0mm Time-Sert Insert Part # 101522
TommyGloves
CHICAGO
Did you try McMaster-Carr? They seem to have everthing
Edit, dif. brand, but same type of insert. I think the size you wanted is here:
McMaster-Carr
[MENTION=109]TommyGloves[/MENTION]
Thanks Dave..I did try MC and Grainger.
I already bought this kit off Amazon. It figures, I get 2 of the 3 holes repaired no problem. The 3rd hole is just a little too short for the insert that came with the kit. FML. :picard:
RICH17
Dr. Pussy Slayer, MD
The 007
Couldnt just drill and tap it for a slightly larger bolt?
02BlueGT
No Fucks Have Been Given
Now apearing in Hanover Park
Grind the inside end down(keeps the best threads on your more used outside end), you can even use a dremel. Make sure to clean the end threads , and that there is a clear start for the bolt. That is an easy fix
TommyGloves
CHICAGO
Grind the inside end down(keeps the best threads on your more used outside end), you can even use a dremel. Make sure to clean the , and that there is a clear start for the bolt. That is an easy fix
Unfortunately, the threads at the end are needed to "Lock" the fastener in place with their driver tool. It's a pretty well designed system. The other option is to install it with Loc-tite...let it set...then file down the outside insert flat with the trans case. Personally, with the amount of stress these bolts see, I want to make sure its done right. If I can't find the right sized insert tomorrow...I may go this route.
EDIT: Here's a quick video of the Time-Cert process. http://www.hrpworld.com/index.cfm?form_cat_id=1093,587&action=category
