Thoughts on engine rattle. Suzuki
NO PUKESTERS
95,587
Timing Chain Rattling Noise On 1999-2002
Suzuki 2.5L H25 Engines
The AERA Technical Committee offers the following information regarding a timing
chain rattling noise on 1999-2002 Suzuki 2.5L & 2.7L engines. This noise comes from the
front of the engine, behind the timing cover, and is normally heard the loudest when the
engine is cold. Vehicles affected are the Grand Vitara & XL-7.
There are three timing chain tensioners on this engine, and causing this problem is the
number 1 timing chain tensioner that is not properly adjusted. In order to fix the problem,
Suzuki recommends replacement of the number 1 tensioner only.
If there is a tensioner noise for the first 5 seconds of engine operation, Suzuki considers this acceptable under
normal engine operation.
Nitrous Chevy
Breathe if you're Horny
Jan 10, 2017
146
America
Here's mine, gets stuck sometimes with the all season tires. Btw you parting it out now? I need a few parts.
