Think i hurt my motor
10thSVT_03
DRRRT PROSPECT
So I was at Byron this weekend and made 3 passes with my car.. 2nd and 3rd pass I blew off the vacuum hoses on the back of the blower.. Spoke with the tuning master and he said they are very important and could lean out the motor under boost.. So I just took a ride around the neighborhood and its drives fine but at idle its kinda rough now and the a/f ratio gauge is going kinda bonkers.. Any idea what I could have done?
Smokey1226
LVN D DRM
this might sound silly, but did you disconnect the battery wires...then re-connect? My brothers truck did the same thing. But who knows
dunno if its possible but computer maybe went into a limp mode? like smokey said, try disconnecting the negative terminal for a bit then take it out for a drive after about 30 min or so?
10thSVT_03
10thSVT_03
DRRRT PROSPECT
I'll try that tomorrow... Only bad thing if I disconnect the battery I have to invest an hour or so in the reprogramming of my AVIC D3 and nav...
Smokey1226
LVN D DRM
wait for more opinions, but im guessing thats what it is. If you said it ran fine, but shakey idle that was the same thing my brother had.
Flatliner
I'm kind of a big deal...
switch out yout FPRS with a good one, check oil see if smells like gas... if it is sensor, change oil too.
gnxs
Corn-Fed Goodness
I'd take a look at the plugs too.
Bob_Kurgan
Flyin_Hawaiin
im worried if it blew a vacuum line off that it wouldnt boost the FP like it suppose too.. pull a plug or 2 and check to make sure they look like they are all there and not collapsed.. THEN, WIRE TIE ALL YOUR VACUUM LINES!!!!!!!!!!
10thSVT_03
10thSVT_03
DRRRT PROSPECT
Yeah everything is wire tied now,plugs are changed and gapped at .30 also...
Hope your fellin better Bob.... I think I will be back at Byron Sunday so if you come into work monday and see my car there you know I broke it...lol
Bob_Kurgan
Flyin_Hawaiin
if all your plugs were in 1 piece, im sure the motor is fine.. i just always thinking worse case scenario.. i hate to see it lean out for some dumb reason!
10thSVT_03
10thSVT_03
DRRRT PROSPECT
Got the sensor.. Now I need a babysitter besides the dogs to watch the kids while I do the install...
Sensor's a 10 minute job. Put the kids in the car and tell them it's pretend ride time. they won't figure it out for a few minutes. Remember to void the fuel in the line or you will get sprayed when you take the sensor off.
90 second install.
1 minute to get a beer.
1 minute to drink the beer.
20 seconds to think there's something you forgot.
40 seconds of swearing when you get sprayed in the face with gas.
3 minutes to clean up.
2 minutes to swap the sensor.
1 minute to get another beer.
1 minute to look at your motor and smile. :)
Tim
I like girls that drink beer
America
best install instructions ever! :lmao:
10thSVT_03
10thSVT_03
DRRRT PROSPECT
Wishing I was home to start my car and see if its all good. I changed the oil,plugs.and sensor... Did smell some gas in the oil also.. Didnt get a chance to start it yet though since the kids were sleeping and it was kinda late.. I will start it tonight though..
blck10th
hose clamp all the vacuum lines that you can. I did not trust the zip ties.
hope all works.
Cliff. thanks for the killer instructions.
10thSVT_03
10thSVT_03
DRRRT PROSPECT
UPDATE!!
Fuel pressure and drive ability is outstanding.. Thanks guys for the input and I will be grabbing a few hose clamps for the vacuum lines..
Thank you again guys!
ShelbyGuy
Turgid Member
step 3a:
cover your hands with a rag so you don't get Cliffed in the face with raw fuel
i have a compression and a leakdown tester if you want to find out how hurt your motor is.
a leakdown test is time and effort for sure. compression test is easy crankin'.
