Damn, that looks right.
Thanks Andy!
Jim, you have a talent for finding wheels to fit ( no pun intended ) your vehicles.
what is your hourly rate ?
would like to find something for a 22 year old f body ?
That does look good tho. Now wash it and get it out in some sunlight!!
felt a tiny wiggle, mighta been the taco bell
Make sure you get that camber sorted especially in the rear. Just looking I can tell there is quite a bit of negative. You'll want it as close to 0* as possible for the best straight line traction.
Thanks Gav! I don't have an hourly rate, but I do obsess over the looks and do a ton of research. You don't like you current wheels?
Do you have the little adapter to put on the end of the torque wrench? You'll need it for the rear Sonnax U-joint.
(I think 13mm is correct, but confirm)
And make sure the front U-joint doesn't bump the bottom of the shifter. I had to grind a lot off and still shim the crossmember.
For the shims, washers work well. They need to be a larger than a quarter in outer diameter. I found some metric washers that had a smaller ID hole that worked perfectly. I used one per spot (four spots), two might be OK.
The shifter starts out flat along the bottom and I knocked off the front and rear corners with a die grinder. In neutral it was OK. 5th and 6th (forward and back) seemed to be the worst.
With my Wiles, it was the weld bead in the way. With the CCI, it will hit the U-joint body.
View attachment 82786View attachment 82787
A lot of the new cars don’t have a lip to need rolling the mustang fenders are already rolled from the factoryi have a buncha old penthouses that have enough pages not stuck together to get them tires to tuck a bit more if ya stack em and set it down, keep it warm and the paints that newer water based shit so it should still be flexible
And yet there are still tards in the S550 groups asking about rolling their fenders. I always reply with why don’t you reach under there and see what you need to roll...lolA lot of the new cars don’t have a lip to need rolling the mustang fenders are already rolled from the factory
