who makes these wheels again?
Which Mickeys are you getting?Mook you'll be getting the call on dem Mickey's.
What size wheels did you go with again? 18's out back and 20's up front?
If you want to run a 28" tall tire, Hoosier makes an actual radial tire that will work. Not street legal, but there is a guy running these on his stick Whipple car getting into the lower 1.4x on his 60 foot times at the track.Yeah 20x10’s up front and 18x10.5’s in the back. The plan is to run a 305/45/18 size tire.
I still need to order a pair of 20x10.5’s
I might look into these next for my 17's.
Hoosier 18830 28.0/10.5R-18 Bracket Racing Drag Radial Slick - Bracket Racer Drag Radial Slicks - Hoosier - Tires - Vehicle Selector - Shop Now (lethalperformance.com)
Have you plugged all your info into a gear calculator? Plug some info in to see where you'll be at by the end of the quarter mile to see if the taller tire is necessary. I imagine you'd be crossing the traps at the top of 4th?I want the taller tire for sure.
Here's a couple calculators that will let you know what speed/rpm you'll be at per gear. Just need to plug in the specifics for your car.
Gear Ratio Calculator (tremec.com)
Gearing Calculator | RPM and Tire Diameter to km/h - mph with Shift Tracer (blocklayer.com)
Will you go thru traps in 4th?
That blocklayer calculator is so cool!Have you plugged all your info into a gear calculator? Plug some info in to see where you'll be at by the end of the quarter mile to see if the taller tire is necessary. I imagine you'd be crossing the traps at the top of 4th?
What will the 28” tire put you at rpm wise?
Need to get into top of 4th time for 4.30s [emoji1787]Yeah I need to shift into 4th. I was trapping around 130 and top of 3rd is around 120ish.
A smaller tire should get my 60' down assuming traction is perfect, but a bigger tire will net me more mph on the big end right?
This car is very serious.
