7500 is pretty low for a coyote with oil pump gearsOh yeah you spinning the motor until 7,500 rpm while I am shifting at 6,300..........
Well I mean you got that massive 6.something liter them tiny little 5.0’s gotta pick up power somewhereI was being conservative!
I spin her to 87500 is pretty low for a coyote with oil pump gears
Lol if that’s basically doubling, then the size of that mountain motor is basically double my tiny little 5.0.
You meant LESS boost, right?
You only make 10lbs!!! [emoji1787]My pulley setup typically makes 14-15 psi on other Cars similar to mine. 14-15
We gotta line up again come spring, if you can make it out...
I’m still wondering why it only read 10lbs...You only make 10lbs!!! [emoji1787]
With you on some sticky tires it should be a pretty good race Id think.We can line up and I am confident you will whack me.
I think you should bring it back with small pulley so it reads 16lbs and see where your at [emoji4]I’m still wondering why it only read 10lbs...
Have a mechanical gauge now and I’m gonna dyno at Drews once clutch is broken in. Gonna tell him to let that fucker eat to 8k!!! Mike was scared to rev past 7500...lolI think you should bring it back with small pulley so it reads 16lbs and see where your at [emoji4]
It’s not an LS...
