The new 2018 Wrangler got awesome- better in every way.
Harbor Master
https://jalopnik.com/the-2018-jeep-wrangler-didnt-get-soft-it-got-much-bett-1821160227
All that time to develop the vehicle brought tons of new features including aluminum doors, hinges, hood, fenders and windshield frame, as well as a magnesium rear swing gate with aluminum skin.
The 3.6-liter Pentastar V6 that had powered the Wrangler since 2012 has been upgraded with two-step variable valve lift and cooled exhaust gas recirculation. Plus, there’s a new 48-volt mild hybrid 2.0-liter turbocharged inline-four joining the mix.
On top of that, the transmissions are all new, the steering is now electro-hydraulic, the whole Jeep is a couple of inches longer, the tops are much more intuitive, the interior is new, the frame is new (and 100 pounds lighter than before in the case of the four-door)... heck, even the door handles got a new design.
Despite being “all new,” the JL is still quintessentially a Wrangler when it comes to off-road capability. Approach, departure and breakover angles—which dictate how aggressively the Jeep can climb, descend and crest slopes without scraping—have somehow gotten significantly better than those of the outgoing Wrangler across all trims. And the last Wrangler was an industry benchmark here.
On the Rubicon model, the numbers go from impressive to downright absurd. The approach angle jumps from 42.2 degrees to 44 degrees, the departure angle climbs from around 32.5 degrees to a massive 37 degrees, and the breakover angle grows to either 22.6 or 27.8 degrees (from 21.2 or 25.8 degrees for the four-door and two-door, respectively). Ground clearance is also up across the board, hopping from between about eight and 10 inches between the diff and the dirt to between about 10 and 11 depending on the trim and tire size.
Practically speaking, that means the Wrangler’s ability to do a mountain goat impression has increased markedly.
But geometry isn’t the JL’s only off-road improvement over the last Wrangler. The crawl ratios are also much bigger than before. The Aisin D478 manual transmission comes with a granny-like 5.13:1 (up from 4.46:1) first gear ratio; when mated to the 4:1 low-range gear and the 4.10:1 axle ratios found in the Rubicon, that yields a crawl ratio of over 84 (up from 73).
The ZF-based 850RE eight-speed automatic transmission also gets a short first gear ratio at 4.71:1 (up from 3.59:1), yielding in a similarly ludicrous 77.2 crawl ratio (up from 58.9). This all means more torque at the wheels, and thus more forward thrust to get the Jeep up and over steep obstacles.
One of my fears going into this as a Jeep “traditionalist” was the CV joints (the part of the axle shaft that allows the wheel to receive torque while simultaneously turning), as they’re harder to fix than U-joints on the trail, and they tend to be more vulnerable. But I learned that those only come on Wrangler Saharas equipped with the optional full-time transfer case (which exists, in part, to pass a stringent Euro NCAP brake test that a part-time system would struggle with). That means most trims, thankfully, will get big, beefy u-joints that can be replaced with nothing more than a big rock and a socket.
Another name for a mild hybrid system; eTorque replaces the alternator with a Motor Generator Unit that charges the 12-volt battery, sends torque to the engine’s crankshaft via the accessory belt, and turns the vehicle’s forward motion into current for the liquid-cooled 48-volt lithium-ion battery.
As far as ever more expensive new cars go, the Wrangler starts out affordable. The Sport costs $26,995 in two-door guise or $30,495 as a four-door. If you want the lockers and 4:1 transfer case, the Rubicon will cost you $36,995 as a two-door or $40,495 as a four door.
After driving the JL, which launches with the V6 in the first quarter of 2018 and with the turbo-four in the second quarter, all of my worries disappeared. The interior is fantastic, the tops are so much better than the outgoing ones, the windshield folds down in a cinch, the doors come off more easily, and the visibility is phenomenal.
Never before have I driven something whose incremental improvements over its predecessor made such a dramatic difference. The JK was already great; but based on my short time behind the wheel, the JL feels like a masterpiece.
Lot's more info in the link, but looks like Jeep crushed the wrangler's redesign.
ilikemtb999
I eat dirt
Denver, CO
And on the other side of the coin, Fred Williams has completely disassembled a new JL and is turning it into an LJ on 1 tons with gigantic tires
Harbor Master
:rofl:
those dudes are so fucking awesome
i need to catch up on dirt everyday
Chester Copperpot
TCGs Far Right Leader
Shithole, IL
Can't wait for the Rubicon Unlimited Call of Duty Skyrim Moab Willy's edition to start at $78k for a fucking Wrangler.
Harbor Master
honestly,
40k for the new rubicon 4door imo is a whole lot of vehicle for what you are getting.
ilikemtb999
I eat dirt
Denver, CO
I always thought the JK looked odd with the gap between the fender and bumper......then the JL came out and I take it back. Being filled in looks weirder.
RICH17
Dr. Pussy Slayer, MD
The 007
Lots of new tech but what worries me is belt wear on this generator motor thingy.
Harbor Master
belt wear?
you serious clark?
Dasfinc
Mrrrrstang.
Wheaton, IL
One of the Dirt Every Day shorts was with the product manager for the JL and Fred, where they mentioned they added the piece for Aero/MPG's, but that its designed to come off with 2 bolts in case the owners want to throw them away immediately.
Harbor Master
right :rofl:
super new hybrid system and rich is nervous about the belt.
RICH17
The 007
belt wear?
you serious clark?
cause you replace the current belt in your car very often?
right :rofl:
Did no one else read this part? You cannot tell me that the belt grip to send tons of torque to the engine to get it going
Harbor Master
dude you realize they just described a fucking alternator right
Harbor Master
right... :rofl:
Harbor Master
n case you missed the full official 2018 Wrangler JL specs which we posted a couple of nights ago, the horsepower and torque numbers were finally released for the 3.0L diesel and 2.0L turbo engines. The 2.0L turbo engine develops 270 horsepowers / 295 lb-ft torque and the ecodiesel puts down an impressive 260 horsepowers / 442 lb-ft torque!
According to our JL Wrangler schedule, the 2.0L turbo Wrangler will start production in January-February 2018 and the diesel Wrangler begins in August 2018.
tinfoilhat
Riding the Hubble
also superchargers use belts and drive WAY MORE torque....so..i think the belt will be the least of the worries.
Harbor Master
Alternator doesnt send power to the engine to POWER the wheels....
but doesn't the engine send a metric BUTTFUCK ton of power through the belt to the alternator :rofl:
bikrboy128
Some say.....
Wheaton
doesn't GM have a similar high voltage alternator for their "hybrid"cars?
this new wrangler looks awesome. finally an interior that isnt from the early 2000s. i hear it doesn't ride like a dump truck either. plus a doozel and hybrid? fuck yes jeep, well done
