Oh jeez, we've been a little strapped for cash the last few months so my car is trying to plug away. Luckily 99% of the stuff I'm neglecting is all little BS things that aren't a negative impact on safety.
-Odometer/DIC hasn't worked in who knows how long...have the resistors to fix, lazy.
-Passenger side window motor took a shit a few weeks ago...have shit jammed in the door frame to keep the window up...lazy
-serpentine belt...isn't bad, just is getting old and I've had a replacement for it for at least a year
-s/c coupler...that and the fluid hasn't been changed in 4 years. I've had a ZZP one/GM fluid in my possession for a couple years now.
-misc trim that is deciding to crack and break, CD drive in the radio freaks out on occasion, and sometimes the key doesn't come outta the ignition until I can get the shifter to click.
Actual bad things:
-needs struts like a year ago.
-Front rotors are just beginning to warp after 2+ years of awesome life. Need to do that before winter hits.
-needs front sway bar bushings and driver's side LCA.
my GF's car... 1998 Honda Civic, Odometer has 237K but has said that for a few years now because the spedo doesn't work either.. lol. Oil changes?? bahh.. the blown head gasket slowly slowly fills the cooling system with oil so we just drain the oil out of the coolant tank and top it off with used oil from the Mustang and Camaro. I change the oil filter once every 6 months. Oil has never been changed since she bought it. we literally never fix anything on it if it costs money. Honestly I don't know how the car keeps going.
and the day you change the oil it seizes up... keep that bitch going!
That's what happened when I changed the oil on a camry.and the day you change the oil it seizes up... keep that bitch going!
On the new truck... but not my fault, I've only put about 200 miles on it
"service overdue" message has been coming on for 20k miles. i should figure out how to turn it off
