I did about two miles yesterday. Rolled the cruiser out, topped of the tank and air in the tires, fired it up. Has a rough low-idle which I suspect is due to a partially clogged pilot jet. High idle ran butter smooth. So after it warmed up I just did a loop around the block to make sure everything was working as intended. Front brake needs a quick bleed, that's about it.
