🏍️ The Motorcycle Thread
Spivitz
The Throttle is ur friend
40,260
46,244
37659
About two hours ago, clutch lever broke in half.
OMG man, I want to pour gasoline all over it and light it on fire
Clutch lever broke, wear and tear.
Hoping I did not smoke the trans riding home clutch less.
I called Ray the Tow guy, my wrench and Harley Davidson. No one available to tow... Thus I fired it up, pushed, kicked into gear and gassed it... Blew all lights, stop signs etc
It's in my garage, I'm back at work.... Need to cool off
  • Angry
Reactions: bikrboy128
Aron
15,194
3,115
You can up and down shift without the clutch and it won't hurt the trans if done properly. You just preload the shift lever with a little tension, then quickly roll off the throttle. It'll slip into the next gear. To downshift, roll off the throttle, load the shifter with a little tension, then blip the throttle lightly but quickly. It'll drop into the next lower gear. When coming to a stop, you can click into neutral and coast to a stop. Taking off is a little tricky, but can be done by clicking it into gear then quickly ease on the throttle
Reactions: Spivitz
Spivitz
40,260
46,244
37659
