First cutting in the bag. Haybine and baler worked flawlessly. Here’s a quick video of the haybine work. I have the raw footage from raking and baling I’ll be working on soon.
Man, that windrower looks pretty nice. Ours looks like a giant pos compared to yours.
I helped my neighbors buy a IH diesel similar to that a few years ago, and it's been a good tractor for them. Maybe it was an 860?
I think they are good tractors that do well on fuel. But, I was told it could be 100° out, and if you walk by it with an ice cream cone, it won't start. Lol
The haybine is pristine and I love it. It was probably an 806, the series prior to these and essentially the same.
These don’t have the same starting issues. The DT 407’s in these aren’t the same pre cup style engines that were in the 560’s, 656 and early 706’s so they actually start. But no lie it was 94 degrees out at an auction yesterday and I couldn’t get a 560 diesel to kick over
It’s the design of the precup engines. They’re essentially diesel converted gasoline engines that run lower compression ratios. In the beginning the Farmall MD started on gasoline and you switched to diesel when it was warm. Second iteration was the introduction of glow plugs, which work OK. The 560 I was trying to start did not have functioning glow plugs.Ether doesn't help em? More cranking amps?
Just curious cause I'm on the lookout for an old tractor to do some light farming..
Applying 32% nitrogen. "Side dressing".
The corn looks rough in spots because of how dry it is.
We did get some rain maybe a week after this picture was taken. Not a huge amount, but enough to keep things rolling. The corn is now tasseling and looks decent, but we are still really dry.
Blew out a tire on the pivot, which ended up being really hard to replace. The size is a 10r22.5, which basically doesn't exist anymore. It really sucks because our pivot isn't that old.
ssweeet fuck ya'll could use rain, the corn around here is at least chest high id think
well fuck add that next timeThat picture was from back around the last week of June. It's 6+ feet tall here now.
8.5x24 maybe? Or just throw a pair of 11rs on the end tower and adjust the speed to keep it in line? I've never once seen a 10r capped in irrigation they stuck it in your ass on that one. Although I spose you could probably have one made up cheap enough.Blew out a tire on the pivot, which ended up being really hard to replace. The size is a 10r22.5, which basically doesn't exist anymore. It really sucks because our pivot isn't that old.
Lol. I said it was tasseling. I figured that would be descriptive enough.well fuck add that next time
Whoever decided to use old truck tires on pop metal wheels is an asshole to begin with though.
