that doesn't look quite right
sickmint79
I Drink Your Milkshake
grayslake
after much time/pain/dollars, cylinder 2 developed misfire has been identified - some ugly arse looking direct injectors.
cyl 4 was still stuck in car. seal compromised on 2. 3 not looking so hot either. close up of 2.
my mechanic says e85 is primarily to blame for this. car purchased in 2012, tracked 2013. e85 early 2015. have run 93 in winters and e85 during track season. 53k miles? many a track day, although driver still slows. might just cycle in some 93 tanks or not run e85 until track day. anyone else ever get this nastiness?
Pressure Ratio
Glen Ellyn
If you don't cycle in 93 every few tanks, you should probably throw something like the Lucas ethanol fuel conditioner. That might help.
sickmint79
grayslake
thought i heard not to use something like that on DI engines or something like that? all out now.
surprisingly the hot 1/3 side i've replaced many a coil pack on looks far better than the 2/4 side.
Escrow shortage crew
I'd do a compression or better yet a leak down test on the cylinders.
10sec
Is there a big enough power difference from 93 to E85 that warrants this as worth the trouble?
sickmint79
grayslake
cold
88 87 88 88
hot just did #2, 87
modest but noticeable gain.
same driver, owns 2 86s, e85 one 93 the other. ab south
if my only change is running 93 between track days and having it last at least as long/longer, tolerable
10sec
Those are definitely good enough for the small sacrifice of switching on track days IMO. HP wise that's probably pretty significant. There's just no way to do this without the destruction? This is 2019, we are in a time where everything is possible...?
sickmint79
grayslake
i'm not exactly clear on the problem. sounds like it is e85, sounds perhaps more accurately that it is additives put in e85? my ports looked pretty clean btw.
the flex fuel kit is all aftermarket. we were going to see if there are injectors that could be used instead that are actually designed differently for e and would perform better. if not i'll just be popping in all new oem ones.
1quick
coal city
E85 is definitely corrosive , I actually just bought some of that Lucas e85 stuff Pressure ratio posted seems legit, feels like an oil of some type one bottle treats like 80 gallons, I’ll probably pull the injectors this next winter and have them cleaned anyway though
sickmint79
grayslake
another guy posted some injectors with 25k miles and 20 autocrosses and 1 track day. his looked pretty good. he thinks some water got on top of mine. seems surprising to have that to happen to multiple though? doesn't really change my plans i suppose either way.
