TH400 install thread
Zack
4 Doors 4 Life
NW Indiana
TH400/Gear Vendors install thread
I got the 4r70w out yesterday without issue, and realized quickly I couldn't lift the TH400/Gear Vendors up on the trans jack myself, so I did the shifter for now.
I didn't think id commplete it in a few hours (less wiring) but I did.
I'll post pics of the trans install here, as well as crossmember modification.
For now, here are the shifter pics:
Here is the console bottom assembly with threaded rod binding posts welded on. Easy to get the height correct with them
I used a sharp punch to puncture the floorboard from inside for the shifter cable:
I later used a piece of small vacuum line to act as a grommet for the hole.
I have to make a trim plate or have a new shifter boot made to take up the gap
And the installed view underneath. I can't believe how smooth everything went
Now I can swap the good driveshaft I took out of this over to my Blue MM.
massacre
Very nice as usual, Zack. I just installed one of those shifters in a '96 GT Mustang track-only drag car. It went pretty smoothly.
Zack
4 Doors 4 Life
NW Indiana
I sprayed on bed liner on most of the accessible undercarriage yesterday.
Gonna get the hard to reach spots with some chassis black.
I'm going to buy my new project tonight (but won't start til spring or summer)
And I started stripping the play field on my High Speed Pinball last night to touch up and clearcoat.
Busy winter!
musclemerc
Post up the pros and cons between the TH400 and a 75RW.
Zack
4 Doors 4 Life
NW Indiana
Um, not sure that's a fair comparison.
Th400 with this shifter gives you the feel of a manual, is no bigger than the 4r and will never break.
musclemerc
Sounds good is the TH400 PCM controlled like a 75RW?
I know Fordnut did this swap (without the GV overdrive) back in the day but he never said why nor did he post the build
Subscribing
Zack
4 Doors 4 Life
NW Indiana
Subscribing
Fordnut has a 4R100 built by Brians Truck shop with a stand alone controller.
The TH400 is controlled by vacuum like stated above or by the driver when a manual valve body is installed. (Like mine)
Curless
Low buck car collector
Grand Rapids
Hey buddy, what are you doing for a speedo input? I know there are options out there just curious what one you are going with...
Zack
4 Doors 4 Life
NW Indiana
The GV has a tone ring and I use a GM pickup and wiring. I really need to get a different tone ring though. The GV has 40 or so teeth and the ford pcm doesnt like it, even when its programmed properly.
I may just tap into the abs sensor like the mustang guys do with great success.
Curless
Grand Rapids
:jg: Cool, just make sure if you do that to use high end connectors, ABS does not like resistance!
musclemerc
Gonna study up on this xmission Zack. Sounds like another great build. Which MM are you putting this setup in? Prozack, turbo blue, or the DD?
RacerX
Zack. Would you happen to have the dimensions for the bracket you made for the quarter stick. That looks nice and solid compared to some I've seen. 4STB-E and hurst sitting in my shed just waiting for Spring. ;-) What are the details on the converter btw?
Zack
4 Doors 4 Life
NW Indiana
I welded the binding posts directly onto the bottom support plate of the console. (The piece the HVAC runs through to the back seat)
It has a 3600 Converter from UCC
RacerX
I see now. I haven't opened that area up yet so it's nice to see other's ideas well ahead of starting my own project.
3600 stall, what's the max rpm you think you'll run the beast at?
Zack
4 Doors 4 Life
NW Indiana
6800-7kish, like usual
Zack
4 Doors 4 Life
NW Indiana
I was able to make some progress the past few days here and there.
First, I brushed on some undercoating:
I used rustoleum from Menards. Comes in a quart and must say....works very well! Have them shake it in the machine before you buy it.
Had my friend over to help me get the trans on the jack...omg that wasnt easy.
Anyway, ran into an immediate problem with the front of the GV hitting the trans tunnel. I had to hack out what is pictured:
Got that done and re-fit it. More problems. The back of the GV is hitting the trans tunnel, and there is no more webbing to remove. I now have to cut a small section out and make a new piece of elevated metal on the inside of the car. When the trans is jacked all the way up into the sheet metal, there is a 1/8" gap between the top of the bellhousing and engine block.
Ill make those modifications this week sometime.
Im a little curious as to what those 2 rivets hold down. Guess we will find out once I cut them out. LOL :jg:
