Tensioner removal on 3800 Series II
Smokinhot
3-man rules!!!!
Lansing, IL
How do you remove it? I haven't gone to check it out yet, but my friends dad says there aren't any bolts to take it off (they just called me).... He snapped the bolt to take the pulley off.
BoostJunki3
Slow M90 Setup
Plainfield, IL
sc belt tensioner and acc belt tensioner i believe you just take off the pulley on the tensioner and deep inside the pivot point on the tensioner there is a 13 mm nut in there you can remove with a deep socket. i know the sc belt tensioner is like this.
DanJoy
Hmmm, don't think i have ever taken the accessory tensioner off.
Harbor Master
u gotta give'r hell. its a bitch to get off... nut in the center of it. unless we are talkin bout different ones... you got a pic?
smug
Cedar Lake, IN
i thought the acc tensioner was part of the alt bracket that has the coolant elbows? Take the alt off and then there are three bolt that hold the whole deal on to the side of the head. You will lose coolant and break the coolant elbows too.
Smokinhot
3-man rules!!!!
Lansing, IL
that sounds about right, i was with them when the picked the car up after it broke and seen it. Its right in that area that your talking about. it on the older model Riviera
DanJoy
Ahh makes sense, I've taken the entire alternator bracket off but never singled out the tensioner. I went through some bolts myself before i realized those were reverse thread... Durrr..
02BlueGT
No Fucks Have Been Given
Now apearing in Hanover Park
There are 3 bolts that hold on the tensoner assembly then the o-rings on the elbows hold it on a bit too..... if you remove the Alt. and coolant resovoir (on the newer ones) it isn't too hard to get the tensoner off
Smokinhot
3-man rules!!!!
Lansing, IL
yea we got it off, the replaced the whole this... fuck changing the belt though, had to remove the motor mount brace :picard: dumb design
Harbor Master
remove the motor mount to change the belt?seriously?
Smokinhot
3-man rules!!!!
Lansing, IL
oh did i forget to mention the PS pump had to come off to to get to 1 of the bolts for the motor mount bracket :picard:
Harbor Master
weird. i did one yesterday on a supercharged car without takin off anything... maybe na cars are different
DanJoy
Is this a 96 to 99 Bonneville? They're the only ones that I know are like that.
DanJoy
Hmmm sounds like a pain in the ass.
