tcg3800s.com
32,642
16,103
F*** the aluminum pan and steel windage tray. It's worse than the steel pan with the plastic windage tray / gasket.
The aluminum pan with the tray removed using the plastic windage tray / gasket is not a bad deal but the rigidity of the pan basically just makes it quieter.
You're basically adding the baffle that they removed from the plastic windage tray to make it so that you can put the giant pick up through the gasket when installing your pan.
Yes there are pictures in those threads unless Photobucket finally deleted all my s***
Reactions: Rdrnnr
v6buicks
6,368
15,814
Franklin, IN
Jon
Welp. Okay then! I found an old thread of yours that should give us newbies an idea.
v6buicks
6,368
15,814
Franklin, IN
Jon
I'll let v6buicks v6buicks try first I'm still a little nervous about cracking this rear cover and gettin it back together right when I pull my trans for converter and flexplate
I mean I'm not one to talk since I botched it, but I don't think it's necessarily anything to worry about. Just get it level with the block to pan surface, crank her down, and RTV the two parts where the cover block and pan meet.
Reactions: Rdrnnr
32,642
16,103
Somewhere in the pages before this one
v6buicks
6,368
15,814
Franklin, IN
Jon
I may I may not. My track record pounding seals in isn't that great but I haven't tried for a while. I'm a socket and a hammer type a guy [emoji23]
Haha I hear that. I don't have any fancy driver either. I've just been lucky using a well placed block of wood and a hammer. lol
Photobucket is gonna murder me for this. Snip and Sketch FTW!
Reactions: Rdrnnr
v6buicks
6,368
15,814
Franklin, IN
Jon
My only concern is that having a welded sheet hug the pick-up tube could make pan removal a huuuge bitch. I suppose that as long as I can sneak my 8mm wrench in there to disconnect the pick-up then all is well. I'm glad you noted the turbo drain shield too. Mines on the other side so it shouldn't be a problem, but I'll remember that if I decide to move it.
Reactions: Rdrnnr
Rdrnnr
wannabe racecar builder
Nov 15, 2020
1,361
2,386
Whattttt is thisss. That things insane [emoji23][emoji23][emoji23][emoji2937]
Rdrnnr
Nov 15, 2020
1,361
2,386
I'm thinking in so many different directions that welding a 3/4" NPT bung sounds like the best way to go for somebody who's indecisive and needs options down the road. At least then I can just swap fittings if necessary and pan removal will never be needed.
Are you for sure its the drain and not just the ebay t70? Cuz I really had no problems and we know how shitboxxy I had my camaro put together [emoji23]
