Going to put this embed here to test.
I ran some tests and found something, although it may not be related to the Safari issue. Regardless of the browser, if referrers are disabled, the embed appears to load fine but videos do not start. That's because Instagram's CDN server (scontent.cdninstagram.com) sends a cross-origin-resource-policy: same-origin header which prevents the asset from being loaded from another domain, www.instagram.com in this case. Obviously, it doesn't make sense for a CDN server to be configured not to serve content used on the main domain. What's weirder is that this behaviour is only displayed when referrers are disabled, otherwise the CDN server sends a more reasonable cross-origin-resource-policy: cross-origin header that allows assets to be loaded from any other domain. If Safari limits the availability of referrers by default, it may be the cause of that issue.
Apart from that, I published an update on GitHub that fixes a potential (=theoretical) issue related to inline event handlers. It doesn't require an update on the XenForo side and I don't think it is related to Safari's issue, but it's not impossible either.
