Getting a late start. My guys woman had a grand opening for her shops. Bunch of my guys there. Liquor started flowing and just now got home.
Either of you guys have gaskets on WSM? It's one of the "must do" mods IMO on WSM. The door and sections of WSM are super drafty. My opinion turns temp control on easy mode for WSM, also conserves coals for longer.pro burns too hot in my WSM. Yes I always fill the water bowl. Seems to be a heated debate whether or not to use it. IMO Weber put it there for a reason, I feel like it helps maintain temp, its a buffer for the lower rack and adds moisture with the smoke
Thats a nice use of trimmings for sure.What to do with brisket trimmings? You guys don't throw them out, do you?
They will make beef tallow if you low temp cook them for a few hours. OR, you can do what I did here and grind them up for 6 lbs of hamburgers. The trimmings were too high a ratio of fat to lean so I added a couple lbs. of N.Y. Strip steak. Then it wasn't fatty enough so I added some chilled wagyu tallow. (OK, I just wanted to add the tallow)
The ground beef is chilling in the fridge now and I will make some patties and freeze most of them later. May try 1 or 2 tonight on the grill if it's not raining.
Grinding the trimmings is like getting free hamburgers. I'm hoping these turn out to be some kind of fantastic wagyu steakburgers. At worst, they'll be good hamburgers. [emoji16]
Amazon has a $30 meat grinder attachment if you have a Kitchen Aid mixer. I bought it a while back and, although made of really cheap materials, it works fine.
I put a gasket around the charcoal door. My lid doesn’t leak yetEither of you guys have gaskets on WSM? It's one of the "must do" mods IMO on WSM. The door and sections of WSM are super drafty. My opinion turns temp control on easy mode for WSM, also conserves coals for longer.
Great ideas!Thats a nice use of trimmings for sure.
I throw the meaty pieces into beans, tallow to smother the brisket later with.
