I was in NYC for a business trip the last few days. We went to Quality Meats in Manhattan and it was unbelievable. Dry aged tomahawk with truffle butter service…I would kill for this
Got such a taste for those. Might do them for dinner tonight or lunch tomorrow
Yes, but not very often. I always lean on the side of over rested rather than under rested. My standard is atleast 3 hours rest with large briskets >14lbs. This particular brisket had a 6 hour rest and was very very juicy but not overdone/deteriorated bark. No stew texture or ends of slices falling apart. I also wrap incredibly tight and a heeping dose of tallow on the meat side. I also increase temps after wrap. 300 degrees-ish. Renders fat really well, but makes done time harder to predict.Coolers can vary in types of insualation so some are better. Just as important, if you have a lot of air space in the cooler, that can contribute to temp drops. I think that's why pros recommend wrapping a butt in a towel in the cooler.
5 hours actually doesn't seem bad for a drop to 160. Are you going for longer storage than that?
Nice! How does he like the Masterbuilt?
Seems like the internet has an answer. Based off Chuds and putting boiling water in before, Yeti seems to have better, but similar temp retention.
Weird because Coleman is roughly half the thickness in insulation to a yeti.
True. Side by side tests i see are more about camping durability then how well it keeps things cold or warm. They all kind of use same metric of how many days ice stays a solid. Seems like for bbq purposes they're not much different.Coleman is a lot cheaper, too.
