That looks so damn good as is
What kind of pit? I always do mine on WSM which has a massive water pan, and the evaporation path directly in the flow up to the meat. So it's inherently humid inside it. On WSM i normally have to get to around 5 hours in before i spray, and spray about every 45 min while checking bark. If i were to do one on a pellet or an offset I'd probably have just a bit earlier strategy (maybe 4 hours in if it needs it) but same frequency at 45 min.MEATeorite
I do a beef brisket like once a year because nobody in my house likes brisket. So my skills and knowledge aren’t that great on briskets. Do you spray yours every hour or so to keep it moist? If so what do you use?
Is there a second rack on pit barrel? If so I'd put a water pan beneath it.I’m using a pit barrel so no place for a water pan. When you do spray, what do you use? I’ve done the beef broth at wrap before. But I like trying different methods.
No prob. Sounds like you got a plan.Unfortunately no 2nd rack. I’ll spray it with water as needed
Thanks
Nice.
Pratt and Whitney?
