I should have them all up by the end of the week. Surprised you don’t see them coming out from speeds sequence he posted earlier. He must have just missed it.
Yeah I was looking for it, must have come out pretty fast. lol
Not showing up. I think Keith got some good ones of my car on my 10.3 pass
I thought this was your preferred way [emoji1787]Don't use tapatalk for image hosting.
So question. We had about 60 racers yesterday.. Maybe a tad less. Should I increase that number for the spring? I can go up to 100.
Definitely need to get on a real tire. I will be on a bias ply next year for sure. Stick cars and radials just don’t work well...My only pass. Should have bought Larry’s 16x10 setup - the ol CSVTDrrrrrrt crew laid out the roadmap years ago and I didn’t follow it. Now I have a broken halfshaft.
Dude your back half on one of those runs picked up 42mph. That car will run 9’s easily if you can hook it up in the lower gears. I saw your car getting crazy when it hit 2nd.
2jz 240
Both runs on iboost setting 3 so around 20psi (out of 33psi on setting 5)
Weak ass burnout
Left on no boost ?
Spun both times on the 2-3 shift so let off and fought my way down
I had an amazing time!!!! Met a bunch of awesome people, glad I didn’t wreck but I wish I could have turned it up.
The car works well on the street but sadly I was not able to replicate that
You need slicks and 2step! Then 9s!Definitely need to get on a real tire. I will be on a bias ply next year for sure. Stick cars and radials just don’t work well...
2jz 240
Weak ass burnout
Left on no boost ?
Pratt says 2-step is badYou need slicks and 2step! Then 9s!
With that said, I welcome any and all feedback.
Msd 2 step and send!! I did it lolPratt says 2-step is bad
I already managed to do it once, whats one more timeBig thanks to Mook for setting up the rental. Had a blast despite the mechanical trouble with the car. Will definitely be at the spring rental.
Try to schedule the spring rental on the same day as an RSD.
No, I sad the WOTBox no lift shifting was a bad idea.Pratt says 2-step is bad
