Did you get smoother shifts?
I'm thinking about switching to Amsoils Universal ATF. It's about $7.00 a quart. If I can get smoother shifts and slightly better mileage, I think it'd be worth it.
Is the gasket the old cork style or is it the plastic style?
I have about 60,000 miles on the car. If I decide to drop the pan, should I also change the filter as well? I've never taken a pan off a car with less than 120K on it.
[/b]
the gasket is neither cork or plastic. it is a rubber/metal mix and you should def. re-use it unless it is flawed/broken/bent but 99% of the time they are re-useable.
theres absolutly no reason not to change the filter ANYTIME you have the pan down on the trans. its only 10 bucks if that, and cheap insurance for you 60 dollar fliud as well.[/b]
