Swimming?
Mr_Roboto
Posts
15,354
Joliet
I know having discussed in passing there are a few people here who have done swimming at a HS level or otherwise. I've been taking lessons and swimming 5 days a week since about last September. Things are going pretty well but I'm still working on a lot of things. I did a ton of back stroke before I started taking lessons and have expanded into freestyle and breast stroke as well as doing flip turns. Combined with my eating I'm down 40lbs at this point and hope to be down another 10-15lbs in a couple months. There's a lot of stuff that I'm working on and having the instructor is more helpful than I would have thought honestly. That said, I do have a few questions I'd love opionions on:
-How the hell do you get power out of the breast stroke? I just don't see it still, I mean it's getting better but I am just not seeing the intensity in the kick I think I should be seeing. It may be my pace though, but I'm probably doing about 28 strokes for a length. Maybe it's more powerful than it feels? Don't really know, just asking.
-Any pointers on building lung capacity? I feel like this is a spot I am particularly short on. It's getting better, although not super quickly. 100 free with flip turns is a bit of a push for me at this point, although I'm getting where I can. I can do a ton of back with flip turns, I just run out of oxygen doing free.
-If I'm doing flip turns I'm having trouble with consistently pushing off the wall too deep. Is there something from a muscle perspective I should be doing to come out more shallow/tune how deep I am coming out? I think this is really hurting me on the above, when I have too much delay in coming up I run out of oxygen quicker.
Posts
6,177
Carol Stream, IL
I’m going to pass these questions on to my mom. She is an avid swimmer in her mid 70’s. Forgot how many thousands of miles she’s recorded.
Question for you though, where are you swimming at and do you like the facility?
Mr_Roboto
Mr_Roboto
Posts
15,354
Joliet
I swim at Inwood in Joliet and love it.
Was playing around with free 50s doing a flip turn and getting into low to mid 40 second range and moderate effort. Flip turning is new enough to me I do not know the boundaries I can hit yet. I would like to be refined enough in what I am doing to knock a couple seconds more off at a minimum but my stomach muscles are sore after so I think that needs some more work.
I am also going to try and add more time as well going from 50ish minutes to an hour and a half a few days a week when logistics permit it
Posts
6,177
Carol Stream, IL
Okay, I passed along the questions.
i used to be an avid swimmer and mild diver. But I messed up something in my shoulder/back where the levator and rhomboid minor attach to the scapula. Doing any kind of swimming motion makes it feel like a red hot ice pick is getting jammed into that intersection,
Only thing I can do comfortably is SCUBA since you don’t use your arms much.
Mr_Roboto
Mr_Roboto
Posts
15,354
Joliet
Get up early beat the rythims of others. It is by f
My left shoulder isn't great, if I miss a few days I feel it bad. If I keep it stretched out it's pretty okay typically not to say it's problem free though. Getting old sucks!
Mr_Roboto
Mr_Roboto
Posts
15,354
Joliet
Good for you! I have an inground pool and barely use it. Need to get motivated.
Wake up early, it's a great way to set the rhythm of your day. If you're not careful or getting up later others set your rhythm and it's not good, it just kills inertia. I go swimming at 7AM daily, then off to drop the kid at school then off to work.
Posts
6,177
Carol Stream, IL
I got an answer from my mom. It’s really long and she did it via text-to-speech. When I get back home I’ll transcribe it and send you a PM.
Just to post something impressive, since October 1985 she has logged 3,520 miles. No joke, 3,520 miles.
Mr_Roboto
Mr_Roboto
Posts
15,354
Joliet
Thanks, that's great. In terms of the mileage I find it interesting that it's logged. She must be pretty serious about it. Over the course of 35 years that comes out to about 2 miles a week on average with a few weeks a year on breaks/vacations/whatever.
Posts
6,177
Carol Stream, IL
Yeah, she inherited the desire from her parents, who also swam regularly.
Those are just the miles she logged when she started going to Wheaton College’s pool. I think it’s because she was able to find an Olympic size pool so the distance would be consistent and easy to track.
massconfusion
Active member
Posts
27
elk grove
There are are three things that are going to be most crucial for you with swimming. Those being technique, stamina and breathing control. YouTube can be a pretty excellent source of info on all three to fill in bits that your instructor might miss. On the topic of breaststroke (that's was my jam in H.S. and college) its gonna be super important to get a proper glide in after your kick. This is where you want to be cutting through the water like a arrow same as when you make your initial off the wall push.
massconfusion
Active member
Posts
27
elk grove
Also if your running out of oxygen after swimming regularly for 6 months or so you're gonna want to look at your breathing control. This is to say getting full breaths during your rotation stage in freestyle. Although to your point regarding working on lung capacity we would do what my coach called hypoxics where we do underwater breast for full lengths and then some. Though if you're swimming alone or in a place with no life guard I wouldn't recommend it.
Mr_Roboto
Mr_Roboto
Posts
15,354
Joliet
I keep getting lectured about my glide. Maybe I need to put some more consideration into it. Is there actually a "thrust" feel to the kicks at all or is it just kind of mushy? I may not have enough velocity in my kicks to be honest or my angles aren't wide enough.
I've been getting somewhat better as my breathing has become better. Right now the combination of freestyle with the flip turns is just kicking my ass though. I'm going too deep and losing too much oxygen before I get back up. As an example I can do 200m back without any real problem doing flip turns, I can do 100 free without much issue without flip turns but the combination of the two is just brutal. When I started though doing 100 free was brutal, so there's definitely consideration there since that was probably 2-3 months ago or so I really started doing it.
I feel like my recovery is probably also shitty overall and that may just be I need to go longer intervals as well. I've been focusing on learning technique and may need to swing back to endurance.
I've dabbled in some of the Hypoxics both just messing around and in lessons, last time I went I made it 3/4 the way down when I was fresh and half way down or so the second and third time. I'm thinking it's not great but it's not terrible either? Definitely NOT something to do in my mind without a life guard there. I want someone to come in after my happy ass if that goes south.
#tcgknowsalittlesomethingaboutfuckingeverything
Beware the collective. We will assimilate you.
Mr_Roboto
Mr_Roboto
Posts
15,354
Joliet
We started doing butterfly kick today. Although it's definitely stronger than my breast stroke kick I feel like it's working muscles that are holding me back on breast stroke and possibly in my other strokes. Although it's been challenging I've been enjoying adding diversity to what I'm doing.
Mr_Roboto
Mr_Roboto
Posts
15,354
Joliet
Are you doing laps with a kick board?
I'm doing some, I try to do at least a couple 50s every time I go. Today I did a 100, day before I did a 150. My legs are definitely weaker than my arms are though and I need to do work there to get the balance a bit better.
