SuperCharger Professionals
mr_gtp
Chicago, South Side
Would anyone know of a performance shop that specializes in SuperChargers, especially on Grand Prix's? I'm looking to drop the factory pulley & put on a 3.4 pulley for my 2004 GTP. I was told that I may need to replace my idler pulley & my tensioner pulley? Also I would need to have everything reprogrammed after I get the pulley change. Has anyone has this work done before? Professionally done!
If so please let me know. I want to get this done. Looking for a creditable performance shop. That does quality work.
Reply on here or drop me an e-mail
[email protected]
chipmonk212121
....you dont need to have anything professionally done for such a minor mod. Just get a 3.4 modular pulley system, a DHP PCM, `80* tstat and 1 step colder plugs. (autolite 104's i think). Find someone with a pulley puller to help take off the stock pulley and pop on the MPS hub and install the tstat and plugs. Plug in the new computer and you are done. Im sure you can find someone on here to do it for you for a reasonable price if you dont want to do it yourself.
chipmonk212121
I just noticed this was an 04'...... get a scanner too so you can monitor for knock before you mod and after
PANDA
FRG
Buy a Intercooler to run a 3.4 on a 04.
audiogob654
you dont really need an idler pully if your just going down to a 3.4 but anything lower than that you will
Fish
From the mean streets....
Chiraq
Your tensioner pulley will be fine. If you start running 3.0 or smaller Id worry a little about the idler and tensioner.
Since you have an 04, Id hold off on the pulley. Get a set of ported exhaust manifold or headers and a downpipe first. You dont necessarily need an intercooler to run a 3.4 pulley but more mods do help. Especially since you have a Gen V blower stock. Think of it this way, you run the same amount of boost with a stock pulley as a 97-03 GTP does with a 3.4 pulley.
mr_gtp
Chicago, South Side
These responses are very helpful.
I just order my new mufflers. I doing a 3inch down pipe also. Is it better with the stock CAT or should I eliminate the cat all together, and have a straight 3inch down pipe?
bluegpgtp
Bourbonnais, IL
[/b]
please do me a favor, buy headers, NO CAT, if you dont, you will be doing it later. and wait on the pulley drop, once u have headers and a decent intake, 104's, a 180 stat u can prolly go to a 3.6 with lil knock.
ive got a 3.4 on my gen III supercharger with those mods and im still knocking 2 degrees. im gonna have to goto 1.9 rockers i think to get rid of it...
trust me... bigger pulley and no knock is faster than a small pulley with 6 degrees of timing...
GOOD LUCK.
