Stupid car won't start....Part 2
zimmer0924
Master Debater
Ok so about a week ago I took a trip to the hardware store to get some things. When driving there the car drove perfect. I come out of the store to find that my car won't start. It's turning over but won't start. After 2 or 3 times of trying I smell fuel and it seems to be dripping from somewhere. So I jack the car up in the parking lot to find that there is fuel coming out between the head and the exhaust manifold. Strange right? So any way I end up having to get the car towed home. Yesterday is the first day I get to work on it after getting it towed home. So I take the plugs out to find a crap load of fuel in the cylinders.
I clean the plugs, cycled the engine with the fuel pump fuse pulled the get the fuel to come out. I got all the fuel out and to be on the safe side I left the plugs out to help evaporate the fuel if there was any left. I change the oil and the frps just to be safe. The next day I come out put everything back together and try to start it but it wont move, not even turn over. It's like something is stuck and holding it from turning over. So being pissed I start pulling everything apart and working my way down. I get down to the lower intake to find a shit load of fuel (like $6.00 worth) sitting in the bottom of the intake. I found later after pulling the exhaust that there is fuel in there too.
So to some it up I have two big issues. A fuel system problem and the engine not wanting to move at all. Some one please help. I could not sleep last night.
SONICobra
ITS STOK
did you do anything to your fuel system when you made your recent upgrades? (im sure you thought about this, just trying to get a picture of what youre working with)
zimmer0924
zimmer0924
Master Debater
Stage 2 fpdm, gt pumps, line upgrade, 60lbs injectors, bap. Normal upgrades. But I had these things when I was running my 2.8h kb with no problems. I'm thinking may be a injector is stuck open or an issue with the crappy gt pumps. I not so much worried about the fuel system as I am with the engine not wanting to turn. Kinda like it is Hydrolocked. If so what then??
Zack
4 Doors 4 Life
NW Indiana
I hydrolocked an engine once from 30 seconds of cranking without it firing. Crushed piston, bent rod...ugly.
If fuel is puddled at the bottom of your intake, thats bad. It kinda means that an entire cylinder had to fill up with gas, fill the intake port then fill the intake.
I wish you the best in solving the problem.
zimmer0924
zimmer0924
Master Debater
Well so far so good I guess. I have no rod through my block. I think with that much fuel filling up in the cylinders it washed them out. So there was no lubrication. I assume everything may have dried out in the cylinder and is stuck I'm hoping. I'm going to go home and spray some pb blaster in each of the cylinders to see if that releases them.
zimmer0924
zimmer0924
Master Debater
Any one know what the resistance should read on a OHM Meter for a 60lbs injector?
Frodo
Im not sure off the top of my head..but you could get a rough idea by taking a number of injectors..ohm them out..and they should all be realitivly close...if one is not then you know that one has issues..
zimmer0924
zimmer0924
Master Debater
Mitch for the save. Thanks, I'm not thinking to clearly right now. Just really pissed.
Frodo
Just trying to help out...that might help you figure out if your injectors are fawked...but still doesnt explain why you have a puddle of fuel sitting in the intake...if an injector was sticking open..yes fuel would run out...but you would think only so much until the rail was empty....this is a very odd situation...and im gonna keep pondering on it for a while
zimmer0924
zimmer0924
Master Debater
It's running out like crazy. It's strange because when I just cycle the key to prime the pumps It says I've got any where from 40lbs-77lbs of fuel pressure before I even try to start it. That's way to much. This is insane to be fine one second and totally screwed the next.
zimmer0924
zimmer0924
Master Debater
Mitch, could it be something wrong with the tune? Maybe it's telling it to throw that much fuel.
Zack
4 Doors 4 Life
NW Indiana
If you did the PRVV delete, the pressure in the lines should drop to zero relatively quickly after the pumps stop running.
You didnt put some sort of aftermarket check valve in for the fuel system did you?
Frodo
I would say no...there is something mechanical/electrical wrong on the car...something failed with caused this situation...now we just have to find out what failed..
Zack
4 Doors 4 Life
NW Indiana
Hey, have you checked for a blown FRPS yet?
If its blown out completely, that would explain the fuel in the intake and the crazy fuel pressure readings. The fuel would be going right through the vacuum line into the intake.
Frodo
i believe he has allready change the FRPS
Frodo
ya know what nick...we should just go return style and not have to worry bout this nonsense anymore...:dunno:
zimmer0924
zimmer0924
Master Debater
You should send me a price and we will see comes out of it.
IZZy
Powered by ES
Damn Nick sorry to hear about your troubles, this is some weird shit
zimmer0924
zimmer0924
Master Debater
Thanks IZZY. Wanting to go fast comes with a price I guess.
zimmer0924
zimmer0924
Master Debater
Just because of a stupid fuel issue. Well I'm going back to drinking now.
01GTvert
Well everyone it happened. FUCK.
yep...that'll keep 'er from startin. Sorry to see the carnage but I doubt going lean will cause a rod to break like that. Lean conditions ussually break stuff from severe detonation. What's the plan now?
zimmer0924
zimmer0924
Master Debater
I was not running lean at any point. It was rich if anything. Fuel flooded the cylinder and was coming out the intake and exhasut ports. The the valves shut with shit loads of fuel still trapped inside and BANG!!!!!!!!!!!!!!!Broke rod. There is light at the end of the tunnel though. The block or the journal on the crank was not damaged at all. So hopefully if I do a quick hone to the cylinder and replace the rod, piston, rings, journal bearings and misc crap I should be fine. Me and a friend scoped everything for 2 hours and everything seems to be fine. I hope I get lucky. Maybe. No one jinx anything please.
