stroker vs boost
gojo83
Cheyenne WY
friendly conversation turned into a back and forth debate.
Details
mine 1993 4 dr 4wd s10 blazer
5.3 l33
spun rod bearing so looking at a 4 in crank or just saying f it and polish the current crank and put different bearings in
stick the P&P 243 heads on
grab a cam from a buddy that is going to a bigger cam.
port and polish and shave the truck manifold
then stick a cable driven TB on it for the swap to work right
6l90e 4wd
since there is no LT headers for the 4wd ls blazer swap I got a lead on a local guy that loves building exhaust
buddy 2006 Avalanche
stock 5.3
looking at a mild cam and worked heads but here is the caveat... he is looking to run a STS type turbo at only like 5-8 psi
If it was a race and i did stick the 4 in crank in and 4.8 pistons would the stroker make beter power or do you think boost is the way to go on all these motors.
E85 would be the fuel and both launch in 4 hi whos setup would come out on top?
OffshoreDrilling
This is my safe space
Chicago
how heavy is a blazer? I'm thinking the avalanche has a good 1000lbs on it.
power will end up within 50hp of each other id say. blazer.
1quick
coal city
Build thread on your blazer please, I will be doing one eventually I've always wanted a turbo ls blazer
Breze84
$ AIN'T NO PITY IN C-NOTE CITY $
Chi-Town....
Blazer would probably win a race but the Avalanche would probably make more power.
gojo83
Cheyenne WY
right now I am in the parts gathering stage. I have a l33 and debating the 4 in crank but after reading the turbo formula thread I am debating a single rear mount boxed turbo setup. I am also weighing the options of the 98+ brake swap or go big and get the GTO calipers off the parts gto and run 17s instead of the 15" snowflakes on it now
Formula_LS1
Keep the stock crank, throw in new bearings, double check to make sure that the ring gap isn't too tight, and boost away :)
Donnie
Ethanol Junkie.
Tempe, AZ/SOUTHSIDE, IL.
That L33 is fucking garbage, you should let me do you a favor and give it to me.
:s00ls:
gojo83
Cheyenne WY
Im not even going to lie I seriously lucked into that one. This was when I didnt know about the 5.3 potentional. I had done some research and was buying it mostly for the 719 heads to stick on the iron head lq4 I have. Then I started looking and holy shit I straight stole it for what I paid and what I got. In typical LS fashion it lost oil pressure spun a bearing guy's wife was pissed and it was her truck it came out of he just swapped it and I took it and had no idea the gold mine I lucked into. Then on top of that the 719s are basically 243s with heavier valves so now I have 2 sets cathedral port "ls2" heads I can work over and slap one on the gto and one on the blazer and see if I cant make 400+ wheel in the GTO with dual 3" cat back and stick a baby snail on the blazer and shoot for 400-600 on it.
Donnie
Ethanol Junkie.
Lucky bastard. I was hunting for an LQ4 or L33 when [MENTION=10801]Ti28[/MENTION] sold me the '02 frankenLS1 he had sitting around. Not gonna complain, the LS1 will do what I want or die trying. But I would have certainly been happier with the 325 for the amount of bewst and abuse is going to be fed to it. lol.
bewst > all
Boost all of the things.
Mr_Roboto
Joliet
JMO, get some forged slugs and some LSA rods. Throw as much fuel system in as possible, and run E85. Head studs in the top end. Profit. A lot. No stroke addition required.
gojo83
Cheyenne WY
just for those that wanted to see the blazer here it is right after I got it. I love the snowflake rim look.
not bad for a 500 dollar grab
