The manifold gaskets were in desperate need of replacement on my 72 Olds. In the process of removal, 2 bolt heads stripped out. Ive been contemplating borrowing a dremel tool and cutting the heads off and using a pipe wrench on the studs.
Before, I start tearing into them that way, has anyone used a more effective way to remove them? Ive seen welding a nut to the head, but have no access to a welder. Is there a bolt out tool you have used effectively, or know of any other method? Any help is appreciated.
Fyi, I've already used pb blaster, and a torch.
