I’m over here just pulling down with no boost gauge lol, it could be 7 it could be 20 I’m just gonna send it either way
Is yours a premium? Just get the Ecoboost center gauges. They're fairly cheap, theyre plug n play, and they look factory.
And here I am sitting at my poverty boost of 10-11psi.
No 40 psi, no care.
You gotta pump those numbers up
That's the most boosts I've ever run in any of my cars. It was probably more like 42 if you want to be technical... Back when I was cool.
Those center stack gauges only come in the performance pack cars, and aren't easily swapped into a car that didn't come with them.Is yours a premium? Just get the Ecoboost center gauges. They're fairly cheap, theyre plug n play, and they look factory.
Tiny 4cyl turbo car?That's the most boosts I've ever run in any of my cars. It was probably more like 42 if you want to be technical... Back when I was cool.
it's crazy but gen2 turbo coyote will make the same power at like 8-9psi as your EVO did on 42psiThat's the most boosts I've ever run in any of my cars. It was probably more like 42 if you want to be technical... Back when I was cool.
That's going to make crazy power , Im guessing around 900rwhp on E85I have a problem. It's an addiction. I may, or may not, have gotten a 10-rib with with a 20% balancer. Maybe.
+5psi. From 12 up to 17
I wasn't going to post this but can't resist. This is the biggest cock tease I've ever had in my life.
How is that even possible.
