LOLDat reaction time needs some serious work bruh...
Wasnt leaving on the light, was sitting there trying to learn how to launch it.
LOL
Don't pull into the second staging bulb until you are ready bruh...
Not bad so you picked up around 2mph with race gas tune over 93 ?
Dynoed on 93Ok , so your dyno sheet posted here is from 93 or race gas ?
Your guess is as good as mine. Maybe the 20" rims are hurting it??? (or the weight as its a fat fucking pig)Trap speed seems kind of low for the power car makes specially in negative DA .you had crazy good DA today at GLD
Shawn, a 1.5x 60' would put you 10.2's or so. What pressure did you run the 20's at and what settings where you in for trans, traction, etc.?
Plenty of these cars have gone 10.2 or so, just need to get out of the hole.
I plan to get a set of 17's at the end of the year, but I'm curious how it will do on the "street" setup with 20's.
Dropped pressure to 20psi. When Tim made the pass he had me drop them to 18psi
was is windy? sometimes a cross wind hits you on the back half and you get some sway
Were you using launch control or just foot braking to what rpm and which DR's were you using again? More seat time will definitely help..
Race gas was in there for every pass, just happened that that last pass was fastest MPH. Probably cause Tim was driving it to log the pass. We never got to bump the timing and take full advantage of the race gas because it started snowing after that pass.
What was the reason for race gas when the car was tuned on 93 ?
