So, flat tappet cams
Mr_Roboto
25,921
31,096
Well, I finally found the source of the knock in the Lemans today. Turns out that #3 isn't even moving the rocker. Cam lobe and likely the lifter are gone. Shit's probably pretty ugly. So to that end, what are the chances in hell that I'd be able to jam a cam in this thing without a rebuild and not spew its guts out. I'm guessing pretty goddamn low? Pontiac 350 (NOT SBC) and a stocker in it now. Also any advice what to get? I was looking at a Howards grind.
1quickbird
Aug 24, 2010
91
Pontiacs are notorious for that, especially once newer oils start getting introduced to them with lower amounts of zinc.
We build a lot of Pontiacs in house here, believe it or not Elgin Industries has a good line of cam's for the Pontiac engines, as well as lifters and even roller tip stock style rockers. Pretty good upgrade for a stock engine. They have cam's that very closely resemble old school Ram Air type grinds.
As far as throwing a cam in and getting lucky about not hurting the rest of the engine. If it has been running with that metal flowing through it for awhile, I would say it's not likely it will survive much longer.
