đź’ˇ Fun fact. Whenever you start a thread, TCG Mechanic 5000 (our AI bot) will reply to you to start helping. It doesn't know everything and it will struggle with more complex questions but it can get the thread going and provide valuable information. You can choose to disable it prior to submitting a thread.
Anyone here who drives a GTI/R with SMF? I really want to experience firsthand how the car shakes inside with SMF. It will be the deciding factor whether I go single mass flywheel or stay with the dual mass flywheel before the tune comes into play.
I have swapped a few dual mass to solid flywheels. If they are balanced for your aplicaction thats a non issue. The problem is transmission rattle mostly at idle. Some times/vehicles won't do it. Others will. Look at your exact type of car with someone that did the swap. The last one I did was a rear wheel drive BMW. It rattled like crazy at idle with an aluminum flywheel. With a single mass steet/cast flywheel it is barely noticable. Lucky for that guy his ebay junk clutch failed so he got to do it twice.
