Nice, I mean just keeping it 15-20° higher than freezing would be good
Yeah I’ve heard that from a couple people nowJFC is epoxy really $8/ft!?
That's crazy. It's not that fuckin hard. Rent a grinder, chase it around, hand do the corners and angles, etch it, clean a few times and lay it down.
Mine does the same and I’ve got no insulation up top. I put an oscillating fan right in front of mine. On super cold days if I’m working out there. I also have a wall mounted heater that runs off propane on the other side of my garage. Turn that fucker on low with a fan in front and I’m in shorts and a t shirt lolHe got the next one down from mine, which has both 7,500 BTU on high and 5,000 BTU on low. Granted his is a 3 car garage vs. my 2, on those sub 30* nights last week, I ran mine on the lower setting (5,000 BTU), at around 1/4 throttle (so to speak) and it kept it between 75* - 77* in the garage.
My guy had his done last November. So far so good after a year.JFC is epoxy really $8/ft!?
Nope, I could have T'd in from the laundry room, but then I'd be dealing with drywall repairs and shit I didn't want to deal with, as the gas meter is on the opposite side of the house.Did you not have a gas line easily accessible to run to the garage? Gas will be cheaper to run when the temps get colder.
Garage heat is a game changer. After having it for so long, I wouldn't be able to go without it.
I recommended exactly that last week as I know how expensive it is to run the electric heater 24/7Did you not have a gas line easily accessible to run to the garage? Gas will be cheaper to run when the temps get colder.
I have a big maxx. Keep the garage at 55* (no clue why you'd heat a garage to 70+) without issue and for not much $, and when i'm working in there i just increase it to 65ish, but normally it feels hot by the time it gets to 63* and i turn it offFor anyone looking to buy a garage heater, keep an eye out on Northern Tool and Menards for Mr. Heater Big Maxx unit heaters. They usually go on sale in the fall. I have a 50k BTU in my garage and my dad has one in his garage. They are amazing. The newer ones are setup to work with smart thermostats, which is really nice.
I'll probably add a wall mounted vent free gas heater at some point in the near future, in addition to the unit heater. My Big Maxx keeps up most of the time, but when temps drop below zero, it can take a long time to bring temps back up after the door has been open for too long. This is a non issue in a smaller garage , but I'm pushing it's limits at ~940 sq feet. Also when I'm welding, the blower fan on the Big Maxx is strong enough that it will blow out the argon shielding gas.
Yup, I'll probably keep mine at 55-60*. Wanted to test how hot it'd get overnight. Apparently the wife went out there for a water this morning and opened both garage doors, before I checked the temp, so realistically the garage got to probably 88-90* before she opened the doors.I have a big maxx. Keep the garage at 55* (no clue why you'd heat a garage to 70+) without issue and for not much $, and when i'm working in there i just increase it to 65ish, but normally it feels hot by the time it gets to 63* and i turn it off
Even when it's cold AF it'll heat the garage from 55 to 63 in like 15 minutes
My garage has an unfinished ceiling so I'm probably losing some heat. It's only an issue when it's really cold out. My gf will open the garage door as she's walking out the front door to the detached garage, and then take her sweet time closing it when she leaves. Leaving the door open for 5+ minutes at a time. When it was -8 degrees F last year, it had a hard time recovering and couldn't get up much above 62 degrees.I have a big maxx. Keep the garage at 55* (no clue why you'd heat a garage to 70+) without issue and for not much $, and when i'm working in there i just increase it to 65ish, but normally it feels hot by the time it gets to 63* and i turn it off
Have we got the thread for you!That reminds me, I should replace the burned out light bulb in one of my openers. I've been saying for the last 6 months that I'll replace it. Maybe today is the day
Update. I did not change the light bulb yesterday.That reminds me, I should replace the burned out light bulb in one of my openers. I've been saying for the last 6 months that I'll replace it. Maybe today is the day
I'm really thinking about putting a circulation fan in our garage.So I think the best part of the garage update so far, is the ceiling fan. Running it in reverse to circulate the warm air that’s risen, has kept my garage at 65°. Had both doors open numerous times yesterday and today, garage got down to 55-56 and shortly after, temps stabilize. Would recommend. Haven’t run the heater since that test overnight.
I considered an oscillating, but it would just push air around instead of proper circulation in regular or reverse mode, season dependent, so I went with this one:
