Should I e85
Pressure Ratio
20,302
11,724
Glen Ellyn
I would probably say pick up a CJ intake then. That intake will make more power and extend the RPM band. I think it will improve ET more than the Flex Fuel tune. The CJ intake is a free tune revision. So the money you save on the tune can be used towards the cost of the intake set up. You can find used set ups for $1000 or so. Picking up .20-.30 in ET @ 4-5 mph is not uncommon.
1quick
26,554
24,004
coal city
I would also need a new nitrous plate for the cj intake
willizm
Very Nice, Very Evil
May 13, 2009
12,829
10,148
The Woodlands, TX
I always figured e85 wasnt THAT beneficial on a NA car but I rode in someones 300hp all motor Honda last week and he mentioned switching to e85 offers a huge jump.....soooo.....i say if you dont mind the 600 bones, go for it.
This is typically the case but I think the coyotes respond well to ethanol even in NA applications. I wouldn't hesitate to run the corn sawse
Pressure Ratio
20,302
11,724
Glen Ellyn
That isn't too expensive and also can find used on occasion. But yes, that will add some to the conversion. Still think the CJ would be more beneficial.
but couldnt you recoup some of that cost in the selling of your currnet plate?
This too.
I would imagine any of these new motors would respond well since they all seem to be very high compression now a days.
Pressure Ratio
20,302
11,724
Glen Ellyn
Correct. They can set the tune to add a limited amount of timing when no knock is detected. But at some point, the extra timing doesn't make more power. So they allow the ECU to add timing to a point. But yes, my point was the addition of E85 is beneficial on these high compression motors as it has extra octane for added timing as well as lower combustion chamber temps. Which also combats detonation.
GIMPY
1,103
I'm not a fan of e85. If it helps u get to ur goals do it. U can always just spray it harder. In my honest opinion if u plan to stick with nitrous I would put a standalone fuel system in the car so ur not wasting good race fuel. You won't have to buy a 5 gallon pale everytime u go to the track. That's one thing I wish I did differently on my camaro.
phat_ridegt
3,351
Ottawa
i dont know about the lund kit, but if the car doesn't use an ethanol content sensor, then it probably uses the fuel trims and o2 sensors to come up with a 'round about' content.
im my experience it will work great, but not good for switching back and forth without plenty of 'learn' time in between wot runs, as mentioned above.
as i was reading this, i was thinking to myself "i bet brett already ordered this lol" good work look forward to going for a rip
1quick
26,554
24,004
coal city
I was going to order it before I even made a thread, then I figured I'll ask Tcg what they think, then this morning I just said fuck it and ordered it lol, If it's any sort of noticeable difference it will be worth it lol
Shibby50
5,005
74
Braidwood, IL
Just seeing where it takes me, I drive past 3 e85 stations on the way to work so I figured why not, it is getting hit with the 150 next time out, I'll be happy with a 10.50 out of it I think messing with the window switch a little more may net a better 60 as well
We can just put in the whenever you want it to work window switch aka a button lol
