Yeah disregard what I said earlier I meant to say that being a member of TCG qualifies you to increase any factory tow rating by 2x!#tcgtowing.
I heard some buzzing after a trip and couldn’t tell where it was coming from. Had to leave dock so out of caution turned both battery switches off when I left knowing only thing wired outside of them is the bilge pumps. Went home and did some thinking and figured it was a pump next time out after a trip heard it again and went to the stairs and raised it and found the shower and AC condensate bilge pump and listened to it pump and heard the motor sound go up and down like it’s on its last leg (everything on last leg on 20 year boat). I’m assuming float switch must be going bad leaving pump on excessively burning it out also. I don’t use shower nor AC so it’s at the bottom of my list for things to do this season.
I need a contortionist to work on my boat too lol Twin 5.7's is the best powertrain option in my opinion.@ rowekmr is balls deep into repairs already. Break out another thousand.
Remember. Boats are fun.
I gotta get the power steering working first. I look like circus trying to dock this without PS and a bad shift cable.Thinking back to this. You might want to fix it for piece of mind and not starting an electrical fire. Looks a Rule pump and float switch, which are common. Open that tank up and just replace both. Again, another DIY type project.
Yeah I plan to do both shift cables, the other alternator, both exhaust manifolds and maybe both starters eventually. Seller said he did the impellors last year but I will get the outdrives serviced and verify those. The tilt indicator is inop so want to look into the sending units on the drives plus the seals and bellows. Thanks for reminding me of the thermostats. The skeg I was going to ignore for now but want the props reconditioned and keep them as spares and get some new ones but have to verify the right size. Any recommendation for shops?Replace both shift cables while you're at it.
If this was my boat and not knowing the history I would replace the cap, rotor, and plugs on both engines. I would also replace the seawater impellers and thermostats. Lastly, I would put in fresh bilge pumps. Overall, not a ton of money in parts and if you're handy everything is DIY.
As for the skeg, that can be repaired where they weld on a "patch" and paint. It will look like new. Last time I had a prop repaired it was about $250 each to repair, balance, and polish.
I'm just knee deep now but knew this one would need some work. I'm somewhat addicted to projects unfortunately.
Don't touch the steering wheel. Use the throttles.
I was replacing the starter. Its either find someone that can fit, or pull the motor.
Hope you get everything sorted out in short order. I shudder at thinking about working on the last boat I owned.
Definitely miss the time on the water, don’t miss the headaches and massive amount of money I was spending
Yes I do/did. I prefer Hammond because it's cheaper than any of Chicago Harbors, Hammond police patrol and sit in lot, and next to riverboat for restaurants, shows or gambling. Also 4-5 years ago they built a mall across from harbor so there's plenty of stores (Super Walmart) and restaurants to stop at. They also have the biggest ramps that make launching/retrieving easier and the best attribute is if the lake is really rough you can putt putt over to the river and take the river tour or go downtown because river is almost always smooth giving you an option when guest are sensitive to waves.Do you have a slip at the Hammond marina? I actually had a slip there waaaaay back when it first opened..
