SCT SF3 Power Flash Mustang Tuner (96-08)
Like new came off my buddys 2007-mustang gt and its only a few months old and made a big difference on his car. the the tuner is unmarried and was removed from his car and was put back to stock and will perfect to give you a high perfomance tune on any of these mustang years. Will work on all these vehicles 96-08 mustangs Works on all V6, GT, Bullitt, Mach 1, and Cobras from 96-08. they retail for $379 and you can buy this one for $250 you can pm if you have any questions.
here is a link for more info on what the tuner can do for you and what they retail for $379 and buy mine for only $250
http://www.ninosport.com/SCT-XCalibrator-3-Power-Flash-Programmer-Mustang-1996-08-3000
The Beast
28,461
32,977
South beach
Go Go
somebody must want to get better GAS mileage and be a bit quicker.
SF3 Power Flash Handheld Programmer
Part Number: 3015
Key Features:
• Latest Flash Technology
• Pre-Loaded with Dyno Proven Tune Files
• Reads / Clears DTC Trouble Codes
• User Adjustable Features
• Monitor Popular External Sensors
• 2008 Models Supported
• Built-In High Speed Datalogging
User Adjustable Features:
• WOT Fuel Adjustment • Idle RPM
• Spark Adjustment • Transmission Shift Points
• Axle Ratio • Fuel Injector Size
• Tire Size - Rev / Mile • Air Intake Selection
• Cooling Fan Temps • Traction Control On / Off
• Rev / Speed Limiters • Two StepOn / Off RPM
* Not all adjustments available on all vehicles
Pre-Loaded Dyno Proven Tune Files:
The SF3 arrives Pre-Loaded with DYNO Proven tune files that INCREASE HORSEPOWER, TORQUE and EVEN FUEL MILEAGE!
Large Backlit Screen:
With a HUGE Backlit display, the SCT SF3 Power Flash makes it EASY to read the Built-In Data Logging or Real Time Monitored Vehicle Data, view popular sensor data such as EGT, Air / Fuel Ratio or any other 0-5 Volt source via the Dual Input Analog port.
Read / Clear DTC Codes:
Using the SF3 Power Flash Device, you can now Read, Clear & Diagnose Trouble Codes without the expensive diagnostic fees charged by dealerships or your local garage
__________________
  • The Beast
  • 7
  • 439
