Royal Purple or Mobil 1?
PANDA
FRG
Well its time to give the GTP the first oil change since I got it. The previous owner used Royal Purple Synthetic for the the 3 years he owned it. Im debating wither to continue to use Royal Purple or Switch to Mobil 1.
tdc30
doesnt really matter but i would use the rp in it since thats what he has been running on only thing is i dont see rp every auto part store i go to
Silvapain
Limestone
I've run both, and I prefer AMSoil; but if I had to chose one of the two I'd go for RP.
TommyGloves
CHICAGO
I would stick with RP. I almost changed to RP this past oil change, but had to go one more since I had the 5 quarts of M1 in the garage. :)
I plan on putting in RP next time.
