Rocker question
mybluegtp
Burbank
If someone would get Rockers could you at the same time change the valve springs and retainers at the same time? basicly all of the things where the rockers go? I was watching Horsepower tv for a breif second when they showed about rocker arms and changing the valve springs and going lighter or something like that. Is this possible?
It should be able to be done. You have to put a fitting in ther spark plug hole for compressed air to hold the valves up. I doubt on the back head you could fit a valve spring remover tool, but I used to just use a deep well socket to push down on the retainer to pull out the locks. I'm pretty sure that is possible on our cars, since valve spring pressure isn't all that much. If you go that route, change the valve guide seals too. They're cheap and easy to change.
Cool, then the comp cam retainers, and valve springs will work right? with the aluminum rockers? and where can you get valve guide seals?
any more ideas?
gtphale
yup you can change the springs and retainers. But you will go up heavier to 105lb. I'm not really sure you would want or need togo up in lbs. though. The stock springs are fine for rockers but if you want it them changed I can do the install for $125 rockers and springs or 75 for just rockers.
mybluegtp
mybluegtp
Burbank
Originally posted by Admin@Nov 9 2003, 08:11 PM
hale... do you know who bluegtp is?
Admin...Mind your own beeswax!!!! :huh:
Hale,
why would it go heavier?
also another questions, what do you need to have to run bigger fuel injectors?
mybluegtp
mybluegtp
Burbank
Originally posted by GTPHales-Wife@Nov 9 2003, 08:25 PM
Am I right....????? Hey guess what I am a moderator  :p
Oh great there goes the forum with flowers and tapax holders.... <_<
:p
mybluegtp
mybluegtp
Burbank
Originally posted by GTPHales-Wife@Nov 9 2003, 08:29 PM
Watch it or I may have you banned!!!!!!!!!!!!!!!!!
:mellow: ^_^ :p :angry: :wacko:
R
Ron Vogel
A lot of people put the LS1 springs in since the seat pressure is just a tad higher. The reason this is done is to take advantage of the upper rpm potential of the rockers. The faster the motor spins, the harder it is for the lifters to follow the cam lobes. A heavier spring helps this. You shouldn't go nuts and put a super heavy spring on, since it takes more friction to run a heavier spring. From what I hear the LS1 factory springs are dirt cheap.
mybluegtp
mybluegtp
Burbank
but do you need to run a cam with this or can you just do it with rockers? and where can you get LS1 springs?
I figure something to do besides the rockers and just change the gaskets, springs, retainers and what else can be done while there?
gtphale
only spring you would want to run is the 105's it just keeps the valve's from floating on you. Little safer but robs a little power.As for injectors you have a long way before you need injectors. Most likely with rockers you won't need them till your running a 3.0 pulley or smaller. Watch your IPW's and see what they are doing.If over 5k if they are 21 or higher your going static but change out the fuel pump first. Go with the Walbro. And yea i'm pretty sure that is Alfredo. And my wife is a moderator that means this club is going to hell.
mybluegtp
mybluegtp
Burbank
so i can use the walbro pump? and yea its me alfredo..:p so i might get the springs and retainers and TB spacer, the Walbro pump, and are the pushrods good to get? I heard they really dont do anything, but yet you can run an inercooler without being camed right? Sorry for all the questions its just i'm planning my route now cause i'm not rich. :(
plmrass
Just get the cam dont be stupid like all of us made the first time!!!!!
mybluegtp
mybluegtp
Burbank
I was but no money for a few years.. :( maybe down the road WAY down the road. :(
BumpinGTP
South Suburbs
with all of the money you are going to be spending you wont be too far off from the price of a cam
I
imported_Diavolo
I got LS6 springs and LS1 retainers. Don't have them installed yet.
gtphale
yup don't need a cam to run an intercooler. You will be able to run alot of advance timing. Pushrods are very questionable if they help. I would say go with the intense lightweight ones if any.And the tb spacer is a waste,save for the ls1 tb comes with an adapter plate that works like a spacer.
Fish
From the mean streets....
Chiraq
Hows that Miller?? 350+100 core +80 to install= at least 500 less than a cam. I thought we discussed the cost yesterday over AIM. :lol:
