Return fuel potential issues, ideas inside.
Zack
4 Doors 4 Life
Mar 21, 2004
6,297
20
NW Indiana
Im gonna start working on the Cobra again soon and the next task is installing the return fuel system parts. They consist of the Fore Triple Return system with GSS342's and all the other related stuff.
Im gonna drive this car, and there will be times I am driving under 1/4 tank of gas. (Im gonna rocket through gas (E85) cause it uses so much more than regular gasoline) so I need to have some piece of mind if I lay the hammer down.
My Marauder sucked the basket dry when it was under 1/4 tank with only 2 pumps....had to go to a sumped tank to fix it. I refuse to have any pumps/lines/sump visible from the back of the Cobra, so I have conjured up an idea.....
I am toying with the idea of installing a 1-2 gallon mini fuel cell in the trunk that is tied into the fuel system in some way. It will get filled up with a T-Fitting from the return line. Then a -10 line will go out the bottom to a fitting in the top of the tank and allow fuel to enter the tank basket via a boost controlled valve (that only opens at a pre-set psi) Then when Im back to cruising the tank will fill back up and the process repeats.
Be honest, is this crazy? Is there an easier way?
Discuss!
gnxs
Electron Powered
Apr 26, 2004
8,930
256
Discuss!
You're always like a mad scientist with this stuff. :p I'm going to be in the exact same situation, but my solution will be to fill up a bit more frequently. Like you, I rarely let the tank get below 1/4 and never race with it under that. I'm going to see what kind of range I get on a tank of E85 before I start looking into other options. I've always followed the K.I.S.S. principle and my fuel system, if practical, will reflect that approach.
Good to see you're going to be a guinea pig with this though. :biggthump Keep us posted with what you wind up doing and how it works out.
Personally, I wouldn't go through the bother and added weight for a mere 1-2 additional gallons.
gnxs
Electron Powered
Apr 26, 2004
8,930
256
Its not for the added fuel capacity gnxs (is your name Larry?) its to keep the basket full so the pumps wont go dry. (when under 1/4 tank of fuel)
Yes.
Gotcha. How big is the tank in a Marauder? I guess I assuming your tank is larger than a Cobras'. In my smallish (16 gal?) Cobra tank I'm still expecting to go ~200 miles before beaing at 1/4 tank. No doubt though that you don't want to starve the pumps.
Zack
4 Doors 4 Life
Mar 21, 2004
6,297
20
NW Indiana
Yes.
My Marauder tank is 19 gallons and I never get more than 200 to a tank (unless Im cruising on a long trip)
I beat the SNOT out of my cars. :clap:
gnxs
Electron Powered
Apr 26, 2004
8,930
256
I don't think you'll have problems with sucking the basket dry in Cobra tank, 03-04 Cobra tanks are baffled tanks , it prevent from sucking the basket dry.I never had problems on my car even when my low fuel light comes on.
I know, my concern is more capacity than fuel starvation. E85 and 16 gallon tank (of which only ~10-12 is usable in "anger") might prove unacceptable.
FuelSlut
FK RED STAR
Nov 9, 2005
1,969
On that note Im glad Im sitting on the sidelines watching this unfold. Im pondering going e85 but want to see more feedback.
Zack just dont go on long trips LOL.
