So for new flexplate this is classic 3800 situation where stock is best stock is fastest right?
I've never pulled just a trans, only them together but it was surprisingly effortless. For real.
The Broken Regal has moved on to high end imports.This thread has James MASSIVELY enticed. Taking away from The Broken Regal getting his shit fixed
So this is okay?well shit good for zzp. must be nice to find the OEM tier 1 suppliers who still have tooling.
might be better than the fun of the meziere fitup
ZZP Heavy Duty Flex Plate
Finally an affordable upgraded flexplate for your Series II and III 3800 car with the 4t65e transmission. It has both torque converter bolt patterns, 258mm and 245mm so you can run either torque converter. This one will not break, it uses a better alloy, 50% thicker than stock, and is "Yellow...zzperformance.com
Is that the billet oneor meziere
Your posts overwhelm mei spent some serious $ balance testing 14 flywheels ive collected over the years at Balancestar while balancing the TR/442's mezieres
i can show you the size and where to drill the holes for changin the 20oz/in balance to the sc 21oz/in and how to debur it and shim the starter.
